09-28-2017, 10:11 AM | #1 |
Rep 599
Drives: M2, C63s, 718 Cayman GT4
Ohlins vs M Coilovers.
Not sure which to go for. My M2 is still in the middle of the Atlantic and I can still have parts installed via the port but idk what to go for. Can anyone attest to the quality of the M Coilovers As well as the Ohlins?
I want something comfortable but at the same time I wanna be able to have fun in the hills here in Northern California. If it helps I live in San Francisco and Sacramento. If you know the road conditions, youd know they're pretty shitty. |
09-28-2017, 11:36 AM | #2 |
Rep 305
Ohlins > M Performance
09-28-2017, 11:45 AM | #3 |
Rep 599
S1monQc223.50 AndrewC198910932.50 |
09-28-2017, 10:56 PM | #7 |
BimmerPost Supporting Vendor
3886
Rep 54,500
Drives: F80 M3
Ohlins R&T
09-28-2017, 11:06 PM | #8 |
Rep 226
I have the Ohlins DFV and I love them. I switched my stock suspenion out at about 5000miles and the ohlins are a bit tamer on the rough roads here in San Francisco but the really bad roads it can be jarring. The jarring ride may be contributed to my chosen ride height and rebound settings.
I am glad I swapped out my stock suspension the car drives a lot tighter in curves with a lot less body roll. I noticed the reduced body roll driving up to mount tam if that helps. |
09-29-2017, 12:20 AM | #9 |
Rep 199
I am in Berkeley and spent Sunday hitting the back roads of West Marin, this car is a blast!!!!....I am getting ready to pull the trigger on Ohlins Road and Track. After doing my homework (reading threads on Bimmerpost M2, M3 and M4 forums), talking with Harold at HP, emailing Ohlins and hearing from Jake there, and talking with a couple of folks who install and personally use Ohlins I am ordering them with approx 15% softer spring rates; plan is to run 80N/mm front and 160 N/mm (standard from Ohlins is 90 N/mm front and 190N/mm rear). I think this will take the edge off, making it a little more supple than stock (I hope). I figure I will start with 18 clicks for street/ back road use and 6 clicks for my 1-2 track days per year.
2017 BMW M2 BSM 6spd with Fabspeed/HJS 300 cell Sportcat, BM3 OTS Stg 2 tune, Dinan Turbo, MST V2 Inlet, Dinan IC, Dinan CAI, Ohlins, Carbon Fiber+Aluminum Strut braces.
2007 BMW 335i (sold); 1997 BMW E36 M3 (sold); 1988 BMW 535is (sold); 1984 BMW 323i Alpina (can't believe I sold),1969 BMW 2002 Ti (spec'd as Ti; and yes I sold this too...). |
S1monQc223.50 |
09-29-2017, 03:42 PM | #10 | |
Rep 120
09-30-2017, 11:44 AM | #11 |
Rep 199
Just reading, talking with lots of folks and collecting info...it is clear that it really depends on where you are planning on doing the bulk of your driving. Being a back roads kinda guy I know I want something that will keep the rear end settled which I am hammering out on Hiway 1 or running out to Marshal on the Petaluma/Hicks Valley Rd....and compliant enough that my wife will actually get in the car!!!
Some folks want it even firmer than offered by Ohlins, turns out the guys at Performance Technic (Fremont) actually went with stiffer springs rates on their 'shop car' but that is because it is really set up for track use... Yesterday I spoke with the folks over at Griffin Motorwerke (got a Fabspeed Sport Cat installed yesterday...holy shit that was an awesome bump in power and sound)in Berkeley; they have a ton of tuning experience and they also thought the spring rates on the Ohlins R&T are set more for track duty. So next I am heading up to Sears Point/Infineon Raceway to talk to some suspension guys up there who come highly recommended...I really enjoy doing the research on projects like this,...kinda the measure twice, cut once philosophy.
horsepower_and_hounds1837.00 mhanism277.00 |
09-30-2017, 11:58 AM | #12 |
Rep 306
Drives: MY17 LBB M2
where's the best (and least expensive) place to purchase Ohlins?
09-30-2017, 02:14 PM | #13 |
Rep 339
I?m in the same boat. Car doesn?t actually get delivered till another couple weeks but I don?t even know where to begin with messing with the different spring rates with Ohlins. I was thinking about just buying them as is with the standard offered rates but figured I need to do more research before purchasing
instagram: @ sf87_m2
09-30-2017, 05:07 PM | #14 |
Rep 199
Harold at HP Autosport in Santa Barbara...he has some comments on this thread...knowledgable and great prices!!!..or of course through your installer...I am planning on going through my installer as he is close to same pricing and is clearly the man when it comes to setting up M2 suspensions in the Bay Area...Aleks at Alekshop; just sayin....
BLUE-BEAST///M247.00 |
10-02-2017, 01:26 PM | #15 |
Rep 105
I wonder if yours and mine are on the same ship!?
I highly recommend the Ohlins. No experience with the M Coilovers, but I have plenty of experience with offerings from Ohlin's on numerous platforms. In terms of a trackable street coilover, they are hard to beat. |
10-03-2017, 12:48 PM | #16 | |
Rep 120
Thanks for the feedback! I've also talked with Harold at HP Autosport the other day and ended up ordering a set. 458/80NM front 896/160'ish (swift springs) Rear. Basically one step lighter on the coils from the stock R & T's. Looks like they're shipping today so hope to get them installed in the coming weeks. |
10-22-2017, 08:55 AM | #17 | |
Rep 199
Thanks.
10-22-2017, 06:38 PM | #18 | |
Rep 339
10-23-2017, 02:40 PM | #19 |
3886
Rep 54,500
Drives: F80 M3
MovingChicane109.50 |
10-24-2017, 10:10 AM | #20 | |
Rep 379
10-24-2017, 10:00 PM | #21 | |
Rep 199
I plan on running it with 15 clicks at first which should be slightly softer than OEM but should hold better on canyon runs than OEM. The following week I plan on adjusting them to 5 clicks and make some canyon runs with things on the stiffer side...I'll keep you posted.
just blaze310.00 BLUE-BEAST///M247.00 |
10-25-2017, 12:45 AM | #22 | |
Rep 339
