F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Will E90 coilovers fit on F30?
ARMA SPEED
      09-29-2017, 07:53 PM   #1
F30Bruhh
Commander
Drives: F30
Ive seen some people say yes, Havent found out to much info on it but heard the spring rate would be off. but lmk please
      09-29-2017, 08:46 PM   #2
the dope steez
Drives: F30 335i M-Sport
I know the rear physically will not fit due to a completely different design
      09-29-2017, 10:11 PM   #3
N0Chill 335i
N0Chill 335i's Avatar
Drives: 13' F30 335i M Sport AW
No.
      10-13-2017, 03:48 PM   #4
FutureHendr1x
Drives: F30 335 Msport
you have no chill dude, no
      10-13-2017, 06:50 PM   #5
N0Chill 335i
I see what you did there. Lol
      10-13-2017, 08:03 PM   #6
Polo08816
Drives: 2014 335i M Sport
You can weld the coilovers to the top hats and wheel knuckle to make it work.
kern4174464.00
      01-16-2018, 09:45 PM   #7
NGD85
NGD85's Avatar
Drives: 2014 BMW 335i sedan
Technically yes and no. Most E90 coil over kits will have a perch of some kind that will fit in the rear. I tried it out on a H&R coil over set.
Rear:
The 60mm Spring and perch fit with some help. The strut wont, its a completely different design. The perch went through the lower arm. You would need to ditch the plastic piece that goes around the arm or cut a hole in it.
Front:
The strut bottom attachment to the Hub is too thin. It will fit inside the hub but move around and have no way to be tightened. You need an adapter like KW sells ( the gold one). If you get that you will need to shave it down as adding it will make the strut too big to fit. you will also need to run an aftermarket top hat as the stock one has too small of a hole to fit and the E90 spring from H&R kit has a smaller diameter than the F30 top hat.
Conclusion:
you can technically do it if you want to hack up the kit and spend some money buying small parts. Although I would honestly just sell the kit and use it to purchase a F30 specific kit.
f30post
