10-03-2017, 05:27 PM | #1 |
Rep 55
Suspension Opinions Needed
Working with a 2013 328i RWD Sedan
19" M Replica 437s with 235/35 Front and 265/30 Rear I am wanting to make the gap between the wheel/tire and the fender closer to the gap of a sport line F30 without going so far as the car looks lowered. I'd like to maintain a pretty close to factory look, but improve the gap i've created with these new wheels/tires and maybe even improve handling a little bit while i'm at it. The current gap is about the width of three fingers (slightly more). The Dinan springs lower the car 20mm or ~3/4" all around. (Maybe 30mm since I think I have a true BASE suspension). The H&R springs drop the car 1.5" front and 1" rear The Suspension Techniques springs drop the car 1.2" all around Last edited by pompous; 10-03-2017 at 07:00 PM.. |
10-03-2017, 07:44 PM | #2 |
Sedan Driver
389
Rep 1,018
get 20 inch rims and tires, style 404
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
10-03-2017, 08:55 PM | #4 |
Sedan Driver
389
Rep 1,018
Thx! my wife says i'm good at that
the dope steez404.00 |
10-03-2017, 09:06 PM | #5 |
Rep 55
I think part of the problem with mine is it's not the sport suspension. So, it looked and continues to look like I'm driving a SUV. I'm wondering if somebody's used sport springs would give me the look I'm after, or if I maybe need the Dinan. Problem is, I cannot figure out if it will drop it 20mm or 30mm
10-03-2017, 09:22 PM | #6 |
Sedan Driver
389
Rep 1,018
H&R sports
Dinan I haven't heard of Suspension Techniques springs. You decide what you like. H&R look lower and filled better in the front
10-04-2017, 09:33 AM | #7 | |
Rep 937
I really wish the performance suspension was cheaper because that's the perfect mix for me. only a 10mm drop and not extremely aggressive and developed strut/spring combo
Hi
10-04-2017, 10:41 AM | #8 |
Rep 456
One item to consider, is your current tire setup's aspect ratio. 235/35 and 265/30 is a very low profile sidewall which actually increases your fender gap. I remember running the same setup on my VMR 810s and thinking how much of a wheel gap I had. Then I changed to 245/35 and 265/35 and saw an immediate improvement on how the wheels and tires "filled" out the gaps. Just something for your consideration...
10-04-2017, 12:13 PM | #9 |
Rep 55
What i'm stuggeling with is there is about a 2.5-3" gap in between the fender and tire (there was even before i switched to the new wheels/tires...it just sat absurdly high in its stock form). I look at plenty of other f30 and it looks pretty decently tight in there and I'm not sure they could fit wheels/tires this size stock. I'm simply trying to achieve that look with a lowering kit without going too far. Its like an SUV gap (and was with the fat tires)...not a BMW sports sedan.
10-04-2017, 07:17 PM | #11 |
Rep 65
Drives: 2017 340ix M Perf, 2019 M2 Cmp
I have Dinan's spring and sway bars on a 340ix MPPSK. Front gap at 1 in and rear at 1 1/8 in.
Hope that helps, Dan |
10-04-2017, 08:13 PM | #12 | |
Rep 4,380
here's the same wheels, stock susp., appropriately sized tires. notice how it lessened the fenderwell gap from the stock 18" setup. stock setup is 26" diameter. 235/40/19, 265/35/19 is 26/4"/26.3" diameters. 235/35/19, 265/30/19 is 25.5"/25.3" diameters, which contributes to 4x4 unless lowered. http://f30.bimmerpost.com/forums/sho....php?t=1422327 |
10-04-2017, 08:22 PM | #13 | |
Rep 55
10-04-2017, 08:40 PM | #14 |
Rep 4,380
ahh, yes, i agree your car is pretty high.
if springs only, i would go with the "highest drop" and bump stop kit, since your base shocks will likely blow out quickly if you lower it too much. if you can afford it, it'd be better if you could obtain bilstein b8 or koni yellow struts/shocks with your lowering springs. and if you go that far you may consider an entry level coilover such as bilstein B14 PSS. pre set damp and adjustable ride height sorry, not trying to make you spend money. but if you go just springs and it blows out quickly you'll end up spending more in the end... |
10-08-2017, 11:22 AM | #15 |
Rep 28
I had suspension techniques springs on my Mustang about 10 years ago. They were good. I haven't seen them for sale for any car since though. Where are you buying those for the BMW? Ebay?
Traded in my 2015 428i Coupe for a 2018 Grand Coupe: Black on Black with red trim.
Upgrades: JB+ | H&R Springs | Spoiler | 20% Tints |
10-09-2017, 05:34 PM | #16 | |
Rep 55
...I picked up both a set of springs from a M and a set of Dinan. I'm going to put the appropriate tires on and try the M springs to see how I like it. If not, I'll try Dinan, and if that's not enough I'll buy the ST or H&R springs and try those. One way or another I will get the right stance lol |
10-09-2017, 06:17 PM | #17 | |
Rep 4,380
10-09-2017, 06:59 PM | #18 | |
Rep 55
Btw...thank you for your help and thoughts in both this thread and the other one. |
10-09-2017, 10:52 PM | #19 |
Rep 4,380
my friend put in my M-performance suspension for me. i helped him by watching ^^ and observed it is above my skill/tool level. while it is not difficult it is tedious and any time you work with spring compressors you have to be careful. it took about 3.5 hours. the rears are reasonable however the fronts dampers are a bitch to remove from and install into its mount.
glad to be of help |
11-09-2017, 11:42 AM | #20 | |
Rep 351
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
11-10-2017, 07:29 AM | #21 |
Rep 3,045
I say go Dinan springs. A few folks have confirmed that you get almost an inch drop which gets you to the M Sport suspension height. Any other spring will drop you even lower.
I've been reading about it for months. I plan to go the Dinan route as I too don't want to mangle my front (CF) lip. Would love some H&R's but up where I am it's not practical. I have to admit though I don't find my current stock suspension offensive. It all depends on the angle of the photo you take. I have always found the 437m style rim to be one of those designs that look out of place on the F30 unless you lower the car.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
11-10-2017, 09:46 AM | #22 | |
Rep 4,380
sometimes springs only or combo springs/struts/shocks drops have uneven wheel gaps between front and back which you are basically stuck with. although it'll cost a little more, i'd do Bilstein B14 PSS entry coilover before the b8/dinan springs combo, since the front spring installs require dis and re-assembly anyway. re: m-perf in addition to the struts/shocks and red springs, the m-perf susp comes with strut mounts(top hats), some nuts and bolts, bump stops and misc pieces so you can assemble it off the car. it did not come with ALL the replacement nut and bolts, so i re-used the old ones in that case, although it is not recommended. at 10mm lower than m-sport the drop is very mild but the suspension is very good and i feel it is worth it if you can afford it. Polo08816 has much more info on m-perf susp if you care to PM him or he responds here. Last edited by alohasurftoad; 11-10-2017 at 10:00 AM.. |
