10-21-2017, 11:30 PM | #1 |
Rep 625
F30 M Adaptive Suspension - Excessive Body Roll?
hey all..
So i drove my friends 328 with regular suspension for a few days and it felt AMAZING compared to my 335 with m adaptive suspension.. we have the same wheels tires etc... When i turn at 20 mph or pull into a parking spot in a mall.. his car just TURNED with no sway or feel of the car turning.. my body / car swings when i turn at 20mph or higher... highway ramps feel like im gonna fly off my seat going up or down the curves.... I have 60k miles on my car (bought it used)... he has 55k... Are my shocks worn? I've checked sway bar bushings they seem fine... No wierd noises except every bump is felt / heard inside cabin |
10-22-2017, 06:30 AM | #2 |
Rep 1,296
You?re probably close to the end of the life of your dampers indeed, so an option is getting them replaced.
However our suspensions aren?t great regarding roll control, even more so considering adaptive suspension comes with weaker anti roll bars than stock, but they?ve been designed to be comfortable and compliant. So I went with KW DDC aftermarket coilovers, as i like the adaptive suspension idea, but with stiffer springs and dampers. In the US you can get Dinan shockware too, which reprograms dampers to be stiffer than stock, and is comparatively inexpensive. Lastly you can get springs but i don?t think that?s a great idea to mismatch springs and dampers.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
10-22-2017, 12:17 PM | #3 |
Rep 3,622
Yea once car has that many miles on it it's apples to oranges. Pot holes, road condition, driving style all affects the shocks. I think if you replaced dampers you'd be in awe.
Also consider getting the dampers from the 340i since they appear to be 10-15% more firm in my estimate from the 335i. If they are compatible on the 335i I would definitely try it
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
MacklinUSOB519.00 |
10-22-2017, 12:42 PM | #4 | |
Rep 937
Hi
10-22-2017, 01:16 PM | #5 | ||
Rep 3,622
10-22-2017, 02:21 PM | #6 | |
Rep 937
"Hey I bought a pure stage 2 turbo"; "Hey I bought bm3" ; "Hey I bought dinantronics" ; "Hey I bought an AP racing brake kit" "Yeah but the n55/f30 wasn't optimized to be paired with it"
Hi
10-22-2017, 03:32 PM | #7 | ||
Rep 3,622
10-22-2017, 04:04 PM | #8 |
Rep 937
The dynamics offered in a dinan/stock combination would be better than stock/stock. Regardless of the "worst case scenario" you just mentioned.
Hi
10-22-2017, 08:13 PM | #9 | |
Rep 3,622
The fact is that the shocks weren't designed for the springs. FYI there's a reason dinan has their Shockware product because it matches dampers to springs There are many unsatisfied buyers of lowering springs. Most driving enthusiasts understand you should always buy dampers and springs that are matching when upgrading suspension.
perryo91376.00 insanecoder1412.00 |
10-22-2017, 11:05 PM | #10 | |
Rep 122
Unlikely that its a result of wear; more likely that your springs happen to be softer than your friends'. Were you driving in Comfort or Sport when comparing? |
10-23-2017, 11:24 PM | #11 |
Sedan Driver
389
Rep 1,018
If everything is the same and it's just suspension difference, i'd have to guess weight difference. Would you happen have the 2 vins to compare? Assuming both cars aren't modded
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
11-05-2017, 02:42 AM | #12 | |
Rep 441
EBII 335i Touring M-Sport (Munich built July 2013)
| 6 Speed Manual | 2VF Adaptive M Suspension | 2VL Variable Sports Steering | 403M wheels | M-Sport brakes | 688 Harman Kardon | 494 Heated Seats | 610 HUD | 322 Comfort Access | 5AC High-Beam Assist | 609 Navigation Professional | |
11-07-2017, 08:29 AM | #14 | |
Rep 529
Full disclosure, the rear suspension of the non-dhp cars is a joke the shocks are way too soft but at least they were matched to the soft progressive springs to try to minimize spring oscillation. With the stiffer linear dinan springs the back of the car seems to just ride on the spring content to just subtly bounce along and wag its tail feeling like the car is towing a trailer at all speeds and on the smoothest of newly paved roads. It is terrible to have such a nice car I love so much feel so unsettled and wobbly and bouncy. Currently waiting for koni yellow rear shocks to arrive in hopes that the additional stiffness on shock rebound will keep the back end of the car from bouncing.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
11-07-2017, 08:45 AM | #15 |
Rep 937
Honestly I have no idea... that's just what I read from their website. I keep reading more things showing that they're not as good as I had imagined. I guess that's one reason why they're so cheap.
Hi
11-07-2017, 09:28 AM | #16 |
Rep 3,493
If you are going to mod cars, it helps to have a little base-knowledge. In the area of suspension, you need some basic suspension theory understanding. There are books on this and it might be best for you to read up on it first. Increasing the spring force overpowers the damping. Lowering springs that do not bottom out need to be a higher spring rate. Lowering springs that start at the same spring rate as OEM will require a much more progressive spring rate later in the travel somehow, with aggressive bump-stops or progressive winding, which will still overpower the damping, but now it'll happen in the most extreme situations, which will probably lead to even more damage. Unless you have adjustable shocks with knobs that you can turn for high/low compression and rebound, stiffer springs will overpower the damping. Even then, often times the adjustments only allow fine-tuning and can't deal with a massive change in spring rate, that usually takes modifying the shim-stack/oil valving springs inside the shocks. You can't get something for nothing. You can't put stiffer springs on there and expect them to work perfectly, the damping needs to be increased.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
11-07-2017, 11:26 AM | #17 | |
Rep 2,651
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
Lancelot576.00 |
