BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding Coding to turn off seatbelt chime & close boot with one fob press
      10-25-2017, 02:56 PM   #1
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
Anyone know the coding in E-SYS to disable the seatbelt chime & to allow the boot to close by pressing the fob button once instead of having to hold the button down?
I'm using E-Sys launcher.
Thanks
      10-25-2017, 09:10 PM   #2
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Then you should be using Launcher Cheat Codes.
      10-25-2017, 09:19 PM   #3
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
Where do you get them?
      10-25-2017, 09:24 PM   #4
Almaretto
Almaretto's Avatar
2374
Included in Launcher. Updated with each release or through Github.
MONDAJ0.00
      10-27-2017, 06:20 AM   #5
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
I didn't know the cheat code feature existed. I found it and activated all the sets of cheat codes available when the program launches (one of them was yours actually Almaretto).
My FA was activated and I was able to code changes 'manually' without the cheat codes (although I didn't know what I was messing with so just tested it would code and reverted it back to how it was right away).
However coding via the cheat codes wouldn't work - There was a cheat code for seat belt chime and another for seat belt warning display. I ticked the box to deactivate both and pressed apply but it said it could not apply the coding. I then tried them individually and it did the same.
      10-27-2017, 11:18 AM   #6
Almaretto
Almaretto's Avatar
2374
Tell me full CAFD name and which codes you tried and I will check out for errors.
      10-27-2017, 12:10 PM   #7
mobilejo
mobilejo's Avatar
Drives: G06 X6 40i
Thanks. I'll do that when I get back to the car with the laptop.
      10-28-2017, 03:12 PM   #8
Almaretto
Almaretto's Avatar
2374
No problem. Whenever you get a chance.
      06-09-2018, 01:41 AM   #9
axz17
Drives: 2018 AW F82
Struggling to use cheat codes as looks like things might have changed a bit. Updated Cheat Codes to the most recent available on Github
CAFD_00001B29_006_004_018.ncd
Attempted to turn off seatbelt (all available choices)
      06-09-2018, 01:47 AM   #10
Almaretto
Almaretto's Avatar
2374
The codes have changed.
      06-15-2018, 10:51 PM   #11
csambitions
Drives: 16 bmw m3
Has anyone figured out where to disable seat belt chimes? Cheat codes no longer work for new fireware, thus this needs to be done manually.
      03-23-2019, 03:31 AM   #12
MONDAJ
with love...
Malaysia
Drives: BMW G30
Dear Almaretto, i cant find the lastest cheat code. and i tried 1 by 1 still cant make it.
Finally done. Just learned Hex and decimal. hurrrray!
      03-24-2019, 12:50 AM   #13
Almaretto
Almaretto's Avatar
2374
      05-03-2022, 11:00 AM   #14
dy63
Drives: F30
hi could you tell me which codes you disabled to turn the seat belt chimes off? im struggling to find which one it is in esys
      05-03-2022, 03:26 PM   #15
Almaretto
Almaretto's Avatar
2374
They are on github.
5post
