Battery replacement
10-30-2017, 06:01 PM | #1 |
The Dark Knight
422
Rep 1,262
Battery replacement
Hi Folks,
Today my service shop told me that my battery is almost dead and it could die on me anytime leaving me stranded. He wants to sell me the OEM battery at $280 + labor. Do you all think that is a good price? Do I have to go OEM battery wise or can I get any other battery as well? If any other than OEM then what do you guys recommend? Also does it need to be programmed or is it just a swap in swap out like we used to do in the older cars before there was such advanced technology in cars? Can i do it as a DIY without any programming cables and tools at hand? Any inputs/suggestions are appreciated ASAP. Cheers, Sam. |
10-30-2017, 08:14 PM | #2 |
Rep 27
I replaced mine with one I bought at Autozone. I did not reprogram although a lot of folks on this board insist on that. I have the INPA software but was too lazy to figure it out. It comes with a lifetime (or is it 5 years?) warranty so I am not worried.
I got my OEM battery to last 8 years because I have a smart charger and would top off the battery around once a month. To save fuel, batteries nowadays are chronically undercharged, which stresses them and shortens their life. So my recommendation to you is to just replace it yourself (it is a bit of a pain but readily doable by anyone with arms) and not worry about the programming. Get a smart charger and it will last 8 years... My autozone battery has lasted over two years now but my computer thinks the battery is 10 years old since I have a 2007 model. It was around $150 if i recall correctly. |
10-31-2017, 07:47 AM | #3 |
Rep 952
Lots of threads about battery replacement so please do a search....
In short, you can almost do it yourself. You can buy any battery, but need to do a like for like replacement to avoid having to re-code. Determine your battery type (conventional vs. AGM) first. Buy a good battery from any reseller. Typical good H8 conventional battery costs about $130. After replacing the battery, you should use software to register the battery (Tell the DCM that the car has a new battery) so it can reset the charge profile and not try to over / under charge the new battery. That's it.
bone stock
10-31-2017, 05:26 PM | #4 | |
The Dark Knight
422
Rep 1,262
11-07-2017, 04:34 PM | #7 |
Rep 1,016
You can put the battery in yourself then pay someone 20-50 bucks to register it if you want. You still will save a ton of money. Or someone on here might be nice enough to do it for you. All you do is hook up a tool and push enter.
11-07-2017, 11:33 PM | #8 | |
The Dark Knight
422
Rep 1,262
11-07-2017, 11:34 PM | #9 |
The Dark Knight
422
Rep 1,262
I read up about Carly and it seems like a great option and fairly easy to do. Any idea if I need a lite version or the PRO version of the App for coding and registering stuff? Do i need their WiFi adapter also or just the cable is OK?
11-08-2017, 01:39 PM | #10 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
You need the pro version of Carly to do anything. Certain features such as battery registration/coding is behind a separate paywall. Coding some modules won't work with aftermarket OBD2 adapters.
Another option is to use BMWLogger (free) and a cheap cable to register the new battery with the same specs. https://goo.gl/9DCUyc https://www.amazon.com/gp/aw/d/B017IG81SQ/ |
11-08-2017, 04:59 PM | #11 | |
The Dark Knight
422
Rep 1,262
How reliable is BMWlogger vs. Carly? |
11-14-2017, 08:31 PM | #12 | ||
The Dark Knight
422
Rep 1,262
11-15-2017, 09:44 AM | #13 |
Rep 1,353
Th PC programs are largely only as reliable as the cable and computer you use.
Use a good cable with a capable machine and you can do far more than you can with Carly. That said, Carly tries to prevent you from making any fatal mistakes, takes reversible and verified backups before programming, and is idiot proof. I use a laptop for anything that falls outside of the things Carly can do, but it is also nice to be able to pull the Carly adapter out of the glove compartment and run other diagnostic programs if I am traveling and encounter a problem. I also use the Carly adapter to run readiness tests before doing an emissions test. |
11-15-2017, 11:49 AM | #14 | |
The Dark Knight
422
Rep 1,262
