Snow Tire Question
11-22-2017, 09:33 AM | #1 |
Rep 313
Snow Tire Question
So I'm running Pilot Alpin PA4s in a square configuration on a 335i sedan, and at the very end of the season last year I hit a giant pothole and ripped one of the fronts to shreds. I replaced the pair so that they would match, but now have two new tires and two moderately worn tires (8/32ns if I had to guess).
Which pair should go front and which pair should go on the back when I mount them this weekend? I'm in midtown Toronto so there isn't usually that much snow to contend with. Thanks for your thoughts. |
11-22-2017, 10:58 AM | #2 |
Rep 44
Most tire experts recommend putting the tires with the most tread at the rear, for RWD and FWD cars. Not sure if your 335i is xDrive or RWD, but BMW xDrive are rear bias anyway and more wear to the rear tires. So put the new tires at the rear for safety and wear.
11-22-2017, 10:40 PM | #4 |
Save the manuals!
6035
Rep 6,754
Why's that? I'd figure you'd want the most traction up front for turning and stopping.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
11-23-2017, 12:00 AM | #5 | |
Rep 44
https://www.tirerack.com/tires/tiret....jsp?techid=52 https://www.theglobeandmail.com/glob...article621608/ http://www.popularmechanics.com/cars...nked-10031440/ |
6ixSpd6034.50 |
12-01-2017, 07:37 PM | #6 |
Rep 2,367
Drives: 2007 E90 323i (Cdn)
Harder to control oversteer than understeer when slippery, why they say put to the rears.
Even under braking, better to have the rear under control.
