12-01-2017, 07:48 AM | #1 |
Rep 757
alignment question
I lowered my car about 1.25 inches and looking to get my camber aligned to closer to factory spec. I do have camber plates up front and fully adjustable arms in the rear (all 3 of them). Do anyone know what suggested alignment specifications are ? i found the shop that will align it they just need the specs ....
2014 Estoril Blue II BMW 328i xdrive ///M-Sport
12-01-2017, 10:18 AM | #2 |
Rep 891
I don't have the complete spec, but the front camber spec is supposed to be -.7~, on the rear you're looking for -1.7~. AFAIK this is for RWD, not sure on the differences (if any) to xDrive.
I would totally suggest adding more negative to the front to subdue the understeer they built into the OE specs, especially since you have plates. If you bolted in F80 control arms to the stock front hubs, you'd be at -1.7 or thereabout, and that is a common mod in the F2X/F3X crowd.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
Domotron150.00 |
12-01-2017, 01:34 PM | #3 | |
Rep 757
12-04-2017, 03:24 PM | #4 | |
Rep 891
http://www.2addicts.com/forums/showthread.php?t=1079766
Domotron150.00 |
12-05-2017, 07:16 AM | #5 | |
Rep 757
MacklinUSOB519.00 |
