Rear Light Not Working
12-20-2017, 08:38 AM | #1 |
Rep 20
Hi all,
Having an issue with my nearside rear light on my 2007 E92. The dash has issued a warning to say that a bulb has failed but on changing all bulbs in the unit it still doesn't light up. I have also tried a new bulb holder but this doesn't work either. The brake light and indicator, lights up but no running light. Any recommendations are much appreciated. Cheers, Joe |
12-20-2017, 09:10 AM | #2 |
Rep 3,201
Drives: E92 325i MSport Coupe
The 'running lights' as you call them are in fact LED bars and if they fail, the whole rear light needs replacing...unless your a dab hand with a soldering iron, in which case this might work:
http://www.e90post.com/forums/showthread.php?t=1441049
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
12-22-2017, 06:28 PM | #3 |
Rep 103
Hi, glad the guide I put together has been useful - even if it's just so you know what's involved.
^ like Phil325i says, on my 2007 E93 only the lightbars ("running lights") are LEDs, the rest (brake, indicator etc) are normal bulbs. I'm based just above Newcastle, and have the spare pair of (faulty) E93 lights I removed, lots of original BMW LEDs, and a few "new" LEDs that I didn't use. Happy to help out if I can, just shout ! For info, I didn't get any "lights out" warnings when my LED lights died, but the foglights in the bootlid seem to have weak contacts and gave warnings even when the lights were ok.
Ex BMW owner (2007 E93 325i, E36 325i & 328i from the 90's)
01-05-2018, 01:09 AM | #5 |
Rep 69
Drives: BMW E92 335i
I'm having the exact same issue , drivers side is dull.. sometimes flickers a little and goes off.... I'm hoping for a crappy connection but I just know it will be an LED problem 😔
