12-29-2017, 12:50 PM | #1 |
Rep 103
Wheels need to be shaved a bit - anyone done this?
I got a set of 18x9 flow forged wheels that in my opinion stick out slightly too much (about 5mm or so) for my liking (25mm more than factory). The offset on the wheels is +40, hoping to shave off 5mm. I have about 10mm of material on the hub side before I get to the tapered lug seat. From what I see 3-5mm is a very common amount to machine off.
Also another option is to pull the fender slightly by a quarter inch, the flat lip on the fender actually angles in slightly on our cars anyway. I'm wondering if this would help make it look a little wider in the rear like the m2. My body shop says not to do this but it seems pretty common online as some people do it along with a fender roll. Any help and thoughts would be great. |
12-29-2017, 06:04 PM | #3 |
Rep 103
12-29-2017, 06:56 PM | #4 |
Rep 5,262
12-29-2017, 06:58 PM | #5 |
Rep 103
12-29-2017, 07:31 PM | #6 |
Rep 5,262
Ah then those will be Canadian millimeters also so might not hit the strut
12-29-2017, 10:28 PM | #7 | |
Rep 103
12-30-2017, 11:25 AM | #8 |
Rep 5,262
In the rear maybe... don't think you can fit 9.5" x 45 in the front....
12-30-2017, 01:28 PM | #9 | |
Rep 103
12-30-2017, 01:40 PM | #10 | ||
Rep 5,262
12-30-2017, 02:48 PM | #11 |
Car Geek
3721
Rep 3,629
With an 18x8" ET45mm offset wheel, I have 5mm of clearance from the front strut tube to the wheel rim on our M240i. 18x9 ET45 wheels will likely touch the front strut, ET35 is probably the least offset that will work with a 9" wide front.
12-30-2017, 05:00 PM | #12 |
Rep 103
That's good to know. No concerns with the front though. Just looking for advice with the rears and pulling rear fenders and shaving hubs etc.
12-30-2017, 05:27 PM | #13 | |||
Rep 103
12-30-2017, 06:27 PM | #15 |
Rep 2,214
ET42 is the sweet spot for the 18x9 square, I don't know that anyone makes an 18x9 et45 wheel? The Apex wheels, in 18x9 ET42, are specially made for 1&2 series cars. I bought my ARC-08 wheels in the 18x9 ET42 square fitment. I have camber adjustment so no concern there, but it does require a spacer to clear the coil spring /perch on the coilovers. Hoping to use 10mm or smaller, will be test fitting in Feb/Mar but this is the recipe that Apex steered me towards, based on my setup and 255 tire requirements.
12-30-2017, 08:10 PM | #16 |
Rep 1,363
9” wide ET 45 will definitely hit the strut. I have 8.5 ET 45 and they hit. Had to install 5mm spacers. Could have gotten away with 3mm, but I want to try 235’s when the 225’s are done.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
12-30-2017, 08:58 PM | #17 |
Rep 525
I have 235s on my 8.5" +40 and there's literally about 3mm of inner clearance with no rubbing issues. In the pic above, though, I'm running a 5mm spacer in the front (steering is also slightly turned) and the fender gets kissed under compression while cornering.
12-30-2017, 10:28 PM | #18 | |
Rep 1,241
*edit* Oops nevermind... realized you were talking rear only and said you had 8" wide et40 up front.
CP911
12-30-2017, 10:29 PM | #19 |
Rep 103
That looks pretty well bang on for the rear. When I do your setup in my offset calculator it comes out to 26mm from hub than stock. When I entered in my 18x9. Et40 is came up with 25mm, but it looks like you have less poke than I do. I wonder if it's the H&R drop compared to my Dinan drop that is pulling the camber in slightly. Do you have any pictures directly down the side of the car?
12-30-2017, 10:31 PM | #20 | |
Rep 103
01-01-2018, 10:52 AM | #22 |
Rep 2,882
So nobody is batting an eye at just shaving off half of the most crucial part of a wheel, and probably one never designed for that?? Have you ever seen what a fractured wheel looks like, or what happens to the car that was running it right as it broke? Might be fine for the trailer-queen car show circuit, but not something you are actually going to ride in. Please re-think this and sell the wheels you can't use and buy ones that will fit (or roll the fenders - you won't die or kill s/b from shitted up bodywork). Even spacers are a bit iffy for true performance driving (especially w/o longer bolts to go with them).
