01-02-2018, 12:17 AM | #1 |
Rep 1,805
Looking to buy HRE FF04, what size do you recommend?
I'm trying to buy the new style and need help with fitment for 20s.
Purchased direct from HRE. -f30 355i xdrive -Brembo BBK front/rear -dinan Springs (20mm) I was an early adopter of the HRE-FF01, and had to use E90 m3 offsets... 20x8.5 +30mm 20x10 +40mm I had to shave the rear wheels and run 265/30/20 which look too stretched for my tastes(275/30/20 rubbed). I want to avoid that situation again. Is this the recommended sizing now that several offsets/widths are manufactured? maybe.. 20x8.5 +30 20x9.5 +42 I don't want the stretched look or have my rear wheels shooting out the side. Are 19s even an option with the BBK?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS Last edited by PabloK; 01-11-2018 at 12:40 AM.. |
01-02-2018, 12:54 AM | #2 |
Rep 4,380
the 19's offsets are too low so you'll have to do the 20's
http://f30.bimmerpost.com/forums/sho...highlight=ff04 |
PabloK601.00 |
01-02-2018, 12:56 AM | #3 | |
Rep 1,805
Seems like I should do 20x8.5 et30 20x9.5 et42 235/35/20 265/30/20
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
10-04-2019, 11:34 AM | #4 |
Rep 28
New here, but really liked these wheels when I saw them. So searched and came to this thread.
I am really interested in a square setup, I see that they now offer 19x9.5 et45. Does that work on both the front and back? I have a set of BBS RGR for my e46m that the fronts are 19x8.5 et32, and I tried those on the front and rear of the 340 and they pushed right out to the edge of the fenders. Im really interested in doing the 19x9.5 so I can run 265 square, that would definitely help with this cars tendency to understeer...then I just need an LSD... |
10-04-2019, 11:48 AM | #5 | |
Rep 356
You can hit up @Slicer on the forums he runs 19x9.5s squared lowered on h&r springs with no rubbing with those specs |
10-04-2019, 04:11 PM | #6 |
Rep 28
But if a 19x9.5 et35 works in the front, then you could run a et45 wheel of the same size with a 10mm spacer. That would make it the same thing. 45mm back spacing with 9.5" width wheels do work in the back it looks like.
