What petrol is what?
01-07-2018, 04:36 AM | #1 |
Rep 149
When I first purchase my car I was putting RON 95/98 into it. Then I discovered the book says 91. So I investigated the different fuels available here and what was what.
I found a report by motoring Australia that said there was no benefit to using 95/98 unless the engine was built to use it. So I used it. One maybe 2 tanks and I started having low speed stuttering. I put injector cleaner in. Not much better. Next tank I went for the good stuff. Shell V Power. So far the stutter has gone and the car runs sweet again. Last week I also did the ECU rest. Driving was not much better until I put in the V power on a near empty tank. So I have a question. What fuels are sold in Germany for BMW to say RON91 is ok. Is their RON91 a better brew than what we have? Thoughts, evidence? |
01-07-2018, 05:19 AM | #3 |
Rep 1,543
From my limited knowledge the numbers shows the octane level of the fuel. higher octane numbers means higher combustion ability. From experience always go with the premium quality fuel (e.g. V power, Mobil, Castrol) as it drives a lot nicer as it gives better response.
01-07-2018, 05:32 AM | #5 | |
Rep 1,815
I have read of a few of you from "Down Under" having the same issues with 91 rated fuel and I do believe that your fuel may in fact be different than European and US fuels. In my 335i (when not running the 95 octane tune), my wife's 328i and my 118i I get better power and more miles to the gallon when running 91 (German 95 aki) fuel over the German 95 (98 aki) fuel. Since Germany mandated ethanol mixed into all of their fuel I have actually lost about 3-4mpg in all of my cars as well. Bottom line, not all countrie's fuel is created equal. Run the lowest octane that your car can run before performance and efficiency starts to reduce, anything over that is a waste if your not running a tune to take advantage of it.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
mfractal39.50 |
01-07-2018, 05:35 AM | #6 | |
Rep 149
Tonight I looked up fuels in Germany. Nothing under RON95. Or what David said. |
01-07-2018, 05:38 AM | #7 |
Rep 149
01-07-2018, 06:03 AM | #8 |
The Cheap Arse Asian
47
Rep 585
The main difference besides the resistance to knocking (premature detonation) with higher ron fuel (in Australia at least) is the difderence in sulphur content.
Aussie fuel have higher sulphur compared to euro, maximum allowed is 150ppm sulphur for ron 91 and 50ppm for 95/98. I read somewhere in Europe their sulphur content is much lower (at 10ppm or something) for their "premium fuels" Many euro cars don't handle high sulphur content of our 91ron fuel (not due to the lower ron) well and i think this is what is causing your issues. Source: info i got from other automotive forums from a guy who's a fuel tank driver. |
DaveSA10.00 |
01-07-2018, 08:11 AM | #9 |
Rep 75
Fortunately up my way (rural SA) there are two BP's. One is OTR, the other isn't. I support local and use the latter.
01-07-2018, 08:17 AM | #10 |
Rep 75
01-07-2018, 09:51 AM | #11 |
Rep 410
The main differences between gasoline standards of Europe and Australia is sulphur, aromatics and the appearance (colour). Australia has a minimum 91 RON and the EU EN228 has 95 RON as a minimum although member states can continue to market 91 RON.
91 RON ULP is a minimum not a maximum so it can vary from batch to batch. Slops are sent back to the refinery for reprocessing and can alter the composition. Australia has a stringent fuel standards act. Vehicles calibrated to meet European emission standards and operate on higher sulphur fuels, such as 150ppm, may have an increase in fuel consumption because of the catalyst being deactivated and require regeneration. However the reduction would be so insignificant it would not be discernible. BMW recommended to the Australian government in the vehicle emissions submission (2016) that fuel quality be aligned with EURO 6 with a minimum 95 RON and sulphur content of 10ppm. For reference you can read Hart report on fuel quality. |
01-07-2018, 06:39 PM | #13 | |
Rep 410
The alternative policy was to be analysed and costed in 2017. Of the five suggested options the Australian government has not placed a time frame of any,if any, phase out of 91 RON. Pricing will be affected as refinery technology will have to be implemented. Like all businesses that cost will not be absorbed by the company. Read the Better fuel for cleaner air discussion paper. |
01-07-2018, 07:34 PM | #14 |
Rep 2,139
Drives: 2009 e92 335i MSport DCT
The price will not go down. Ever. Aus335iguy jan 2018
Quote me in a few years
When you doppelkaplung you doppel your fun.
01-08-2018, 02:21 AM | #16 |
Rep 149
I'm on 98 atm and it's running sweet.
The manual needs an update if Australian RON 91 is as crap as it sounds. So much for Australia having hi standards |
01-08-2018, 02:45 PM | #18 |
Rep 149
Lesson learned. I had tried 95/98 in other cars and saw no benefit. In a BMW it certainly seems to make a difference. So far my stutter has not reappeared with V Power
