01-13-2018, 02:50 PM | #1 |
Rep 284
G30 Best Things to Code
Whilst waiting for delivery of my G30 (due in March) I wanted to work out what if anything is worth coding on it.
Having used E-Sys I know my way around the software but I'm not sure if there is anything worth coding. Previously in my M135 I coded Enhanced Bluetooth and before that in my older 1 series I coded the digital speedo. What are the most common things that people use it to code? |
01-14-2018, 12:04 AM | #2 |
Rep 8,364
Coding is personal preference thing. It also depends on region. On this side of the pond, we have to code in options that are factory in other regions (NGHB, trunk closing, etc).
Other than that, I code the common things like:
01-18-2018, 02:13 PM | #5 |
Rep 4,210
I also used Almaretto and would recommend him. My codes were:
ACC- closest distance Nightvision - turn on spotlight change default driving mode from comfort (I had it changed to adaptive) activated anti-dazzle light feature traffic jam assistant at max speed on all roads blind spot detection at 13 mph |
10-20-2018, 04:40 PM | #6 | |
Rep 14
How's the process/ cost
What did you need to provide on your end for Almaretto to complete the coding procedure remotely, and how long did it take? Could you share the cost as well? Thanks in advance! |
10-20-2018, 06:30 PM | #7 | ||
Rep 18,751
nitrocris0.00 |
