N54 No Coolant (HELP!!!)
01-22-2018, 05:21 PM | #1 |
Rep 310
Ok so I was driving home from my girlfriends house today, not more than a 15 minute drive tops. A minute or so after I left her house the low coolant symbol popped up. Didn't really think much of it, I hadn't added coolant in awhile and it was a short drive so I was gonna too ip when I got home. Well I got home and put my car on ramps so I could look for leaks. Checked all the hoses no leaks or anything so I look at the Drain Plug for the radiator.....IT WAS GONE!!! I drove my car for I don't know 12-15 minutes without coolant In it. The Oil temp gauge did go up a little quicker than normal but never got above 200 (Again it was a short drive) do I need to be worried about whether or not I may have warped my cylinder head/blew my head gasket? The dealer won't have the part till Wednesday so I can't start the car or anything until then. I was going to run out to Harbor freight to get a compression tester so I could test my head but do you think it's necessary because of how short a drive was and the fact that the oil never got over 200? The car also never whent into limp mode and the coolant warnings other than low coolant never popped up. And help would be greatly appreciated!
01-22-2018, 05:53 PM | #3 |
Rep 310
01-22-2018, 07:38 PM | #4 |
Rep 310
This is the way I'm looking at it right now (until I get the chance to test it) On normal highway drives in the summer I normally see 220-230 oil temps and people who track there cars see upwards of 250-260 degrees. My oil temp gauge only ever got to 200. Am I crazy in assuming that nothing bad would have happened?
01-22-2018, 07:44 PM | #5 |
ahat
1040
Rep 2,592
my old n54 began to dump coolant out less than about 10 mins and 2miles away from where I turned it off after a clamp (1 day after thermo/WP install by indy) broke. Oil temp went to 265. Water never went red. It was about 1 yr ago and its still running fine with new owner - 135K miles.
I would do an oil sample or two. Depending on age and other $ you got in it.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
01-22-2018, 07:46 PM | #6 | |
Rep 310
01-22-2018, 08:17 PM | #7 |
ahat
1040
Rep 2,592
Nope, started looking for a replacement. It had been using oil and I didnt want to know what the coolant dump was gonna do. The new owner has since found a loose block fitting and it doesnt use any oil according to what he said. Sounds normal on cold starts and warm.
01-22-2018, 08:27 PM | #8 | ||
Rep 25
01-22-2018, 08:34 PM | #9 | |||
Rep 310
01-22-2018, 09:46 PM | #10 | ||||
Rep 25
