Fob stopped working
05-30-2008, 05:33 PM | #1 |
Critical Care Anesthesiologist
484
Rep 8,828
Drives: SMB F83
Fob stopped working
The entire Comfort Access system is down, not only that, the remote lock/unlock also stopped working on both fobs. No code stored any where and no warning lights on. Don't know what this is related to as the CA and remote entry utilizes two different antennae and circuits.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" Last edited by Kev; 06-05-2008 at 03:30 PM.. |
06-01-2008, 03:23 PM | #2 |
Rep 9,946
http://www.e90post.com/goodiesforyou/DIY-DoorSills.pdf
that the official diy might help |
06-01-2008, 04:00 PM | #3 |
484
Rep 8,828
Drives: SMB F83
Thanks man. I think I had it figured out, but need to go back to the shop tomorrow to test my hypothesis. It's most likely not related to the doorsills, but will ask them to check those out too.
"your friendly neighborhood critical care anesthesiologist" |
06-01-2008, 07:57 PM | #5 |
484
Rep 8,828
Drives: SMB F83
The wiring is the same on both. Just that there are two more doorsills than the E90
06-05-2008, 03:28 PM | #6 |
484
Rep 8,828
Drives: SMB F83
Update: Found no wires unplugged, spliced, or cut when we inspected it on again Monday.
Day 1: Took the car in for service today and they couldn't quite figure it out yet. Will keep updating this.
"your friendly neighborhood critical care anesthesiologist" Last edited by Kev; 06-06-2008 at 04:44 PM.. |
06-05-2008, 07:26 PM | #8 | ||
484
Rep 8,828
Drives: SMB F83
06-06-2008, 02:40 PM | #9 |
484
Rep 8,828
Drives: SMB F83
Mini update:
Day 2: After another full day at the dealership, they cannot not isolate / locate anything wrong with the car. No codes stored in any module, and no harnesses unplugged. Problem submitted to BMWNA for further analysis. At my request, they also attempted to remove to illuminated doorsills, which they believed was the culprit of the malfunction, and the malfunction did not correct itself, just as I suspected.
"your friendly neighborhood critical care anesthesiologist" Last edited by Kev; 06-06-2008 at 04:45 PM.. |
06-07-2008, 09:44 AM | #10 |
484
Rep 8,828
Drives: SMB F83
Day 3: Service Department is open today, still waiting for BMWNA to chime in.
I suspect that this is more of a coding / module issue. I asked them if they could try to reflash the DME on the car, but the SA thought that I was crazy and told me that they have to adhere to "protocols". I guess I'll wait for BMWNA to chime in.
06-09-2008, 10:38 AM | #11 |
484
Rep 8,828
Drives: SMB F83
Day 4: Had not heard from the dealership yet. This is slowly getting frustrating. I'll probably call the SA up again in the afternoon and see if they came up with anything.
No phone call from SA, wife called in for me due to me having my SHELF exam tomorrow. They said that BMWNA is now involved, but at this point they still have no idea what is going on. .
"your friendly neighborhood critical care anesthesiologist" Last edited by Kev; 06-09-2008 at 03:12 PM.. |
06-10-2008, 05:27 AM | #12 |
484
Rep 8,828
Drives: SMB F83
Day 5: About to leave for my SHELF exam, and will likely check in with the dealership afterwards and report back.
According to SA, the shop foreman and service manager are invovled, and if they found that the problem is related to "aftermarket parts" or "installation", BMW will not cover this under warranty. However, they still have not been able to find ANY problem wrong with the car as to the reason why the remote and CA went offline on their own. Dropped off a list of modifications to the dealer. There are no modifications done to the vehicle's electrical system, other than the illuminated doorsills, which they have eliminated as a cause of the malfunction. Talked to the tech directly and he states that he has been closely working with BMWNA to get to the bottom of this. At this point, it doesn't appear the malfunction is in any way related to the "aftermarket" parts.
"your friendly neighborhood critical care anesthesiologist" Last edited by Kev; 06-10-2008 at 03:22 PM.. |
06-11-2008, 08:14 AM | #13 |
484
Rep 8,828
Drives: SMB F83
Day 6: Still no end in sight, will follow up
06-12-2008, 04:32 PM | #14 |
484
Rep 8,828
Drives: SMB F83
Day 7: Solution has been found. Seems like a fuse that is specific to the antenna system is blown. The dealer is replacing the antenna module tomorrow just to be safe. The car should be ready tomorrow night.
06-14-2008, 12:02 PM | #16 |
484
Rep 8,828
Drives: SMB F83
Nope, everything is covered under warranty because it is caused by a bad antenna module and it has nothing to do with the "mods".
