Oxygen Sensor or ECU?
01-30-2018, 08:07 PM | #1 |
Rep 123
Hey boys, need some help.
Got a check-engine light, read code in Torque app, showing as: P0050 - Powertrain - HO2S Heater Control Circuit (Bank 2 Sensor 1) Ordered one of these from Amazon: Bosch Original Equipment 17098 Oxygen Sensor Which is for Bank 1, as it was a) half the price of Bank 2 and b) I've read many comments from people who successfully installed it in Bank 2, noting simply that aside from the identical connector & sensor the cable is a bit longer. So I had my local BMW-specialist shop install it. Unfortunately, the car still throws the same code and he now believes the ECU may be bad. So: how likely is it that the issue is the new sensor (or the bank 1 vs 2 issue) throwing the exact same code. Or something to do w/ the ECU? How likely is the ECU to fail w/ something like this? Don't want to keep buying sensors to investigate. How would you boys proceed? |
01-30-2018, 08:59 PM | #2 |
Rep 459
I suspect you got a knockoff sensor. I got a knockoff and got the exact same error code.
Perhaps swap your sensors and see if the code follows the sensor. |
01-31-2018, 08:33 AM | #3 |
Rep 123
01-31-2018, 10:50 AM | #5 |
Rep 123
01-31-2018, 11:09 AM | #6 |
Guest
Rep n/a
Drives:
Hmm...I've ordered many a brake pad from them (mostly Akebono units) with no issues. They're pretty well respected on Amazon and Ebay, I'd be surprised if they were selling non-authentic goods.
02-01-2018, 12:11 PM | #7 |
Rep 123
UPDATE.
My shop put in a brand new sensor and got the same exact code, so it appears the sensor is not the problem. He said he can spend time diagnosing the wiring to make sure e.g. a mouse hadn't chewed on the wires, but that it could take up to 4 hours. I told him to spend up to 2 hours on it and get back to me. What do you guys think, should this be trivial to diagnose -- is there a way to confirm it's the ECU and not the wiring w/out spending up to 4 hours on it? Cheers! |
02-01-2018, 04:26 PM | #8 |
Rep 123
2nd UPDATE.
He found a melted cable about 2 feet from the ECU running towards the sensor. The car runs fine w/ a brand new cable + Bank 2 sensor. Now I gotta decide whether to shell out another $150 for the brand new Bank 2 sensor or leave the replacement Bank 1 sensor (Bosch 17098) that is supposed to be usable in both banks. |
02-01-2018, 08:03 PM | #10 |
Rep 123
Yeah, that's what I told him to put back in. Should pick up the car tomorrow. Not sure why the wire melted, maybe a previous mechanic messed things up w/ insulation while changing the valve cover gaskets, etc.
02-02-2018, 06:14 PM | #11 |
Rep 2,973
Replace the sensors in pairs just like bulbs.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
