What is the holdup with MHD's Bluetooth support?
02-22-2018, 09:22 AM | #1 |
Rep 404
Im sitting here trying to cobble together some sort of always powered display for MHD gauges and getting frustrated with the lack up bluetooth from mhd. Ive subscribed to threads that discuss this but there have been no update's in some time. Whats the hold up? is there anything the community can do to help with development? are we on the cusp of BT and im crying for nothing?
BTW, love MHD!, hate the cable that trys to kill me. Sincerely, this guy.
Mods related to trouble shooting posts: Stock Turbos, MHD OTS V7 stage 2+ 93 oct, VRSF Downpipes, VRSF Relocated inlets, CTS Turbo 7" Intercooler, Tial BOV with upgraded line 5.56mm, index 12 injectors, A/T OEM Flash.
02-22-2018, 01:45 PM | #2 |
Rep 1,484
probably mainly time and resources. he could help make a bluetooth adapter or finish his f series flasher.
you can probably guess which will make him more money. you'll probably start seeing more bluetooth development after they finish there f series flasher
Current Ride=2008 BMW 335xi
2017 BMW M240 Xdrive 2017 BMW M2 N55 6spd 2018 Infiniti Q60 Redsport AWD 2008 BMW 335ix |
Faredo312.00 |
03-15-2019, 10:26 PM | #3 |
Rep 404
A year later, still nothing.
03-16-2019, 04:51 PM | #5 |
Rep 404
the latency wouldn't be noticeable. Im trying to mount my tablet without switching cables just to charge. The only solution i can think of is to add a micro USB port directly to my tablets battery leads. The only reason why i haven't already is im not sure if it will backfeed power to my OBDII port.
03-19-2019, 05:30 AM | #6 | |
ASCMA General
51
Rep 157
03-19-2019, 08:43 AM | #7 |
could-be bmw tech
17
Rep 71
Drives: %E2%80%9809 335i
Exactly what I did, mounted a wireless charger to the back of my tablet mount. Only problem was that it wont wirelessly charge a Nexus7 if the data cable is plugged in at the same time, but does make it easier to charge when not reading data.
Jet black e90 335i LCI | MHD/xHP | BMS DCI | ER cp w/Synapse BOV | ST coilovers | mufflers are still there
03-19-2019, 02:06 PM | #8 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
That is really annoying. I really want to mount a tablet 24/7 but I want it to charge and have live gauges etc. There has got to be an easy way...I mean it is just software...I assuma custom jail breaked OS would fix this.
03-19-2019, 02:32 PM | #9 |
2007 335i E92
44
Rep 624
Speaking of tablet charging, anyone find a way to get fast charge type power? I have my cable routed into the center console and plugged into Quick Charge 3.0 and it still loses battery power while on full time when driving.
2007 335i E92 AT - MHD E85 Flash, xHP Stage 3 , MR5 Intake, VRSF DPs, VRSF 7in FMIC, ER CP, Fuel-It Stage 1, RB PCV, UUC Corsa Exhaust, BL R8 Coils, Sachs SRE Coilovers, M3 Control Arms, H&R Sway, BA Diff Lock, MDF Scoops, Tint, CF Hood, Mini Battery :: 2011 X3 xDrive 35i - MHD Stage 1, Alum Charge Pipe
03-19-2019, 02:42 PM | #10 |
Clean is the new cool, keep it that way.
808
Rep 1,685
MHD will have a wifi adapter, not BT, and there was issues with a manufacturer but they have a new one and it is in the testing phase now, should be released soon enough.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
TemjinX2520.50 |
03-19-2019, 02:49 PM | #11 |
Rep 1,040
I use the JB4 BT connect kit to my iPhone and there is no noticeable latency, it's actually very impressive.
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon. |
03-22-2019, 01:37 PM | #13 |
Rep 404
I had a member contact me who had an extra tablet that supports 2 USB ports on one device. I remember looking for this last year with no luck, i may have been searching the wrong keywords, but they can be found now.
03-22-2019, 01:46 PM | #14 |
Rep 2,476
Finding an Android tablet with dual USB ports isn't difficult, the tricky part is finding one that's smaller than 10".
A while back when tablets as head units became a thing, the Nexus 7 was a popular choice and custom kernels were written for it to support all sorts of things. |
03-22-2019, 01:59 PM | #15 | |
Slow.
3782
Rep 7,152
Can you link me to a decent one with dual ports so I can charge with one and have gauges with another? Or a single if USB Type C actually works? I am fine with 10'' or larger, I want to be able to see my gauges with a quick glance.
03-22-2019, 02:21 PM | #16 |
Rep 1,484
you can probably just use this adapter
but i'm not sure if the new versions of android support otg and charging at the same time. i know on the older android versions you needed to root it and have a modified rom that supported it. https://www.amazon.com/Adapter%EF%BC...gateway&sr=8-4 |
Johnnyd931.50 |
03-22-2019, 04:14 PM | #17 | |
Rep 2,476
I just googled "Android tablet dual USB" and several came up, mainly the Acer Iconia. I didn't search long. I wasn't able to charge with an OTG cable along with a USB to analog/optical adapter using USB C on my Pixel phone, so I'm skeptical of it, as well. |
03-25-2019, 07:41 PM | #18 |
Rep 404
I can confirm that the lg g pad x will infact charge with micro USB while simultaneously using standard USB to communicate with MHD.
Now to work out a mounting solution. I've also purchased 90* ended USB cables.
03-25-2019, 07:58 PM | #19 |
Rep 231
Is there a better way to place the OBD cable as it’s really easy to kick out
03-25-2019, 08:00 PM | #20 | |
Rep 404
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
03-25-2019, 08:13 PM | #21 |
Rep 231
03-25-2019, 08:25 PM | #22 | |
Rep 231
