do these cats look gutted ?
02-26-2018, 03:41 PM | #3 |
Rep 552
second picture looks like after market resonators with some black sharpie art work for the M symbol .. as for the first picture I can't tell.
2009 335i xDrive 6MT // Black Sapphire / Cold Weather / M Sport / PDC / Premium Package / Aerodynamic Kit / Anthracite headliner / Keyless Entry / AR Design Catless Downpipe / Style 313 19" Wheels/ OEM Euro Taillights / LUX H8 160
Antetokounmpo1551.50 N52 Moistenor19.50 |
02-27-2018, 11:53 AM | #4 | |
N54 Whisperer
20
Rep 71
The first picture looks normal to me, I doubt someone went through the trouble to mess with the stock downpipes. I did notice the hardware isn't stock though. Looks like someone removed the downpipes and didn't use the OEM nuts so they might have installed catless downpipes or took them off for maintenance. |
02-27-2018, 12:02 PM | #5 | ||
Rep 9,209
02-27-2018, 12:45 PM | #6 |
Rep 78
thanks everyone, I drop the exhaust to check it out. I'm having trouble with the catalytic monitor not clearing, that might have to do with it.
02-27-2018, 12:50 PM | #7 |
Rep 9,209
02-27-2018, 02:21 PM | #8 | |
Rep 2,973
They have no effect on O2 readiness. They are behind the second set of O2 sensors. If you are having issues with the O2 sensors being ready, make sure they are good. If you have more than 100K miles and are having issues with readiness, they might be bad. I had O2 sensors go before 100K miles and most recently replaced all mine about two years ago.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
02-27-2018, 02:42 PM | #9 | |
Rep 78
here's a part list http://www.realoem.com/bmw/enUS/show...diagId=18_0686 (is it 1 & 2 or 4 & 5 ?) is this the correct aftermarket part number ? NTK25676 thanks!! Last edited by anorphirith; 02-27-2018 at 02:57 PM.. |
03-02-2018, 01:00 PM | #10 |
Rep 78
so apparently this is the unspoken solution
http://www.e90post.com/forums/showpo...2&postcount=23 http://www.vr-speed.com/vrsf-catless...-bmw-335i.html |
03-02-2018, 01:51 PM | #11 |
N54 Whisperer
20
Rep 71
Not sure if this is what you're looking for but when I replaced my O2 sensors I used this post: http://www.e90post.com/forums/showthread.php?t=726481
03-02-2018, 03:07 PM | #12 |
Rep 1,965
Maybe there is something wrong with me but I was slightly disappointed to find no gutted cats in this thread.
fordbaxter19.50 |
03-02-2018, 03:57 PM | #13 | |
Rep 78
03-02-2018, 04:43 PM | #14 |
Rep 807
Drives: 2011 335is 6MT
Mixing up the signals in the post cat O2s can cause codes as well (either installing the O2 in the opposite pipe or mixing up the connectors).
03-02-2018, 05:14 PM | #15 |
Rep 78
03-02-2018, 05:27 PM | #16 |
Rep 807
03-03-2018, 01:54 PM | #17 |
Rep 78
03-03-2018, 10:04 PM | #18 |
N54 Whisperer
20
Rep 71
03-03-2018, 11:21 PM | #20 |
N54 Whisperer
20
Rep 71
I'm not 100% sure on this but it tells you the name of the flashed file so if it's not stock it should be somewhat obvious. Or pull logs and look at the boost to see if it's stock
03-04-2018, 12:00 AM | #21 |
Rep 78
fordbaxter19.50 |
03-05-2018, 08:40 PM | #22 | |
Rep 78
edit I"m pretty sure it's stock based on this: Last edited by anorphirith; 03-05-2018 at 10:40 PM.. |
