Turbo Oil Lines
02-27-2018, 01:44 PM | #1 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
To all, I might be in a situation where I think I have an oil leak in the turbo lines. Most likely it's a gasket or two. My car has 150k on it and has original turbo. There is no wastegate rattle after performing both fixes a while back.
My question is do most people just replace the gaskets and clean out the lines with brake cleaner and compressed air, or do you go ahead and replace the lines all together? I saw an oil line kit at ECS for $300.00. It comes with a quart of oil. I'll probably tell them to keep the oil. I am thinking sometime in the next 25k, I'm gonna have to replace the turbos I know. Please Advise.... 07 335i Sedan |
02-28-2018, 08:34 AM | #3 |
Rep 6,968
02-28-2018, 09:25 AM | #4 |
Guest
Rep n/a
Drives:
100K miles
Can't remember if I was doing DPs/wastegate adjustment at the same time(which obvi would have made things easier)...remove the splash shield and get under there to have a look see. If it's your front turbo, gasket replacement is pretty straight forward; just cramped for space. |
02-28-2018, 11:46 AM | #5 | |
Rep 6,968
