03-02-2018, 09:23 PM | #1 |
Rep 176
Is everything really covered under CPO? Might need new shocks
Or at least that's what I think is making that noise when driving through road imperfections.
Thanks! |
03-02-2018, 10:50 PM | #2 | |
Rep 10,473
And cosmetics and car squeaking is certainly not covered. |
03-02-2018, 11:10 PM | #3 |
Rep 5,776
It's hard to give an answer as your description is vague as to the problem. Need to know when the noise happens, what the noise is and how many miles on the car.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
03-03-2018, 11:50 AM | #4 |
Dü Werke
420
Rep 87
Struts are considered wear and tear items and won't be covered.
I purchased my vehicle CPO (and out of state) and suspected my struts were blown after a few weeks of driving the car around town (very floaty and FR to RR movement seemed unmatched). I talked to 3 local dealers who all told me CPO will not cover struts, but were all more than happy to quote me ~2k to replace all four corners... LOL. If you're up for some DIY (or have a good independent mechanic), Bilstein has OEM style replacement struts (B4). ~$300 gets you all four corners. |
03-03-2018, 03:55 PM | #5 | |
Sedan Driver
389
Rep 1,018
Again, used car buyers should have a trusted mechanic inspect the car before buying. Don’t just blindly trust cpo label
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
03-04-2018, 08:18 AM | #6 |
Rep 891
As said already, shocks and wear items and won't be covered by any extended warranty, maybe a maintainance plan but I haven't heard of one that does.
I recently made the jump to KW V2's at 64k. After taking my old shocks out I was able to compress the fronts easily by hand and the rears with a single hand... If you're up by that mileage it's a good time for replacement. Keep in mind when you're purchasing struts or coilovers, they're going to cost about the same to install so if you were thinking of an upgrade, now is the time.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
03-24-2018, 03:25 PM | #7 |
Rep 176
It's hard for me to explain noises, but everytime I go through a road imperfection ie small bumps, it makes a noise as if I was hitting something, and it's something I don't get on my e46.
There's also a squealing noise coming from the back sit, anyone know that one as well? I did get the maintenance plan from the dealer, anybody know if it may cover it? |
03-24-2018, 03:33 PM | #8 |
Rep 16,198
04-02-2018, 10:37 AM | #9 |
Rep 36
I just had my front passenger side strut replaced free of charge when I took my car in to do a routine oil change. The maintenance guys discovered the leaking strut when they were doing the oil change. It was due to the wife hitting a pothole a couple weeks prior.
04-26-2018, 12:24 PM | #10 | |
Rep 176
04-26-2018, 12:46 PM | #11 |
Rep 10,473
04-26-2018, 01:37 PM | #12 |
Rep 348
I'm not sure about CPO but my original warranty covered and replaced the front struts.
The front strut was leaking, wasn't dripping or anything; front strut and spring replaced. Rear squeaking, creaky sound over uneven surfaces; Spring pad upper rubber & ball joint replaced all free of charge. |
04-26-2018, 02:32 PM | #13 |
Rep 1,130
Source: http://cpo.bmwusa.com/warranty
WHAT IS NOT COVERED Suspension Ball joints; bushings; center tie rod; coil springs – sagging (except for leveling system pneumatic/hydraulic springs); control arms and brackets; idler and pitman arms; stabilizer bar links and supports; strut elements/shock absorbers (dampers); tie rod ends and adjusting sleeves; trailing arms, thrust struts; wishbones. Body Editorial Comment: Make you wonder why anyone even buys into the CPO products. Last edited by zinner; 04-26-2018 at 02:37 PM.. |
anotheran389.00 |
04-30-2018, 10:43 AM | #14 | |
Rep 351
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
04-30-2018, 11:02 AM | #15 |
Rep 474
Drives: 2014 328D xDrive
04-30-2018, 03:22 PM | #16 |
Rep 537
Though the majority of wear/tear items are not covered under CPO, they are almost all covered under the prepaid maintenance contract. When we bought our F30 last month, the car had 43k miles and was still under factory warranty until 50k. CPO warranty is an additional year and unlimited miles. We paid for an additional CPO year and 3 years of prepaid maintenance for $3,400. This was expensive up front, but pennies compared to the actual maintenance/repairs for 3 years of ownership. I bring this up as almost every wear/tear item is replaceable under the maintenance program.
05-01-2018, 07:09 PM | #17 | |
Rep 10,473
You made your Dealer’s month. |
05-01-2018, 09:02 PM | #18 | |
Rep 3,958
05-02-2018, 08:26 AM | #20 |
Rep 474
05-02-2018, 11:51 AM | #21 |
Rep 3,958
I don't think the brakes are going to reach that price even at the dealership, particularly for a non M car. Also, I have 91,000 miles on my M Sport Brake Option brakes and it's still on the original rotors. That includes running M3/M4 stock brake pads at the track.
05-02-2018, 12:06 PM | #22 | |
Rep 474
However; the dealer quoted me $2600 to do all 4 pads, turn rotors, and do a brake flush... Base model F30 brakes... And I had to replace my pads at just over 65,000 miles; I replaced the rotors as well since I could get a package price (I did them myself, not at that insane dealer price). |
MacklinUSOB519.00 |
