Injectors or MOSFET??
03-07-2018, 08:55 PM | #1 |
Rep 72
Hey guys. I know this has been run through before, but it never hurts to get personal input. Today I was accelerating into a lane with basically 100% throttle. It was a normal pull for about 3 seconds and then there was almost a "boom" and the engine light came on and the car would idle at like 450rpm and almost die. Had no power and was misfiring. Luckily I was a block from home and drove carefully back. Read the codes and came back with:
29cc - Combustion Misfire several cylinders 29cd - Combustion misfire cylinder 1 29ce - Combustion misfire cylinder 2 29cf - Combustion misfire cylinder 3 30ba - Injectors 1,2,3 or DME, Internal fault. I'm fairly sure it's the MOSFETS but would the entire bank 1 go like that? Let me know what you think, thanks. All the plugs and coils are fairly new. |
03-07-2018, 09:20 PM | #2 |
Rep 779
2012 shouldn't have a problem with MOSFETs. Injectors are always a potential, but probably not likely in this case.
If you're on the stock charge pipe, check it at the throttle body. If it's solidly attached, check the rest of your IC piping. "Boom" during boost is something under pressure letting loose. |
03-07-2018, 09:48 PM | #4 |
Rep 779
In that case, MOSFETs definitely move up the list. Not sure on the “boom” though, unless it was something related to a cut. I’ve hit some limiters accelerating WOT that felt like rear-ending an invisible car at 50mph lol
Not that big a job to pull the DME to confirm or rule it out and they're way cheaper than injectors, so I'd start there. I'd give the physical stuff under the hood a once-over first though, just to make sure the boom wasn't something else. |
TemjinX2520.50 |
03-08-2018, 03:47 AM | #7 |
Rep 459
It's almost certainly MOSFETS.
An injector failure is very different, one cylinder cuts out and you get injector codes. When you see 30BB or 30BA on a car made before 03/08, it's almost always MOSFETS. Fortunately it's a relatively inexpensive repair. |
feuer4277.00 |
03-08-2018, 07:20 AM | #8 |
Rep 9,209
Not every 30bb and 30ba can be repaired with Mosfets replacement. Been there. I know. Also, thankfully not very often, when the Mosfets burn they damage the injectors too. So potentially could turn into expensive repair quickly.
03-20-2018, 10:16 AM | #9 |
Rep 72
Replaced all 6 mosfets. Cleared codes and car runs better than ever. It is strange, I have never felt my car run this well. Almost leads me to believe that mosfets can degrade over time. Probably just placebo though. Thanks for all of the input!
03-20-2018, 12:35 PM | #10 |
Chartered Accountant
66
Rep 970
Any chance you can link to the mosfets you ordered? I think I need to replace mine as well.
03-20-2018, 01:11 PM | #11 |
Rep 72
https://www.digikey.com/products/en?...DB14N30TMCT-ND
Make sure you get the FDB14N30TMCT-ND not the FDB14N30TM |
03-20-2018, 02:14 PM | #12 | |
66
Rep 970
LOL $13 for all 6 mosfets instead of buying a new DME for $1,300. |
03-22-2018, 01:42 PM | #13 |
Rep 513
Drives: 08 335i
Where did you take it to replace the MOSFETS? How much did it cost?
2008 335i E93, DP's, 7" FMIC, DCI,CP TIAL Q BOV, MHD Stage 2+, Alpina Flash
03-22-2018, 02:05 PM | #14 |
Rep 922
My DME MOSFETS blew up 2 months ago in a similar fashion.
I basically have no experience with electrical engineering and didn't trust any local TV shops (the few that are left) to work on this DME, most likely for the first time, so I sent it off to: https://n54dmerepair.com It's $250 for the service, which depending on how you look at it could be a steep price or not. Remember, a new one costs upwards of $1500. Sure, the MOSFET parts are $15, but it's also very easy to destroy the DME if you don't know what you're doing or don't have the proper tools. The service was well worth it, all 6 MOSFETS were replaced, tested, and my car has been running great since I got the DME back a month ago. Basically plug back in, and play! |
03-22-2018, 02:24 PM | #15 |
Rep 9,209
$250 for repairs on MSD80 is way too much. It should be around $80 to $120 max. MSD81 upgrade runs about $400-450 for used part and programming. If you want to keep MSD80 buy Mosfets and have any TV or computer repair shop to swap them for you.
03-23-2018, 05:35 PM | #16 | |
Rep 922
There are several options with varying convenience, risk, and price. Like I said, I just went through this a couple months ago and I couldn't be happier with my decision. Of course it always depends on how cheap you want to be with the repair. |
03-23-2018, 06:06 PM | #17 | |
Rep 9,209
03-14-2022, 06:09 PM | #21 |
Rep 2,020
One could by replacing the mosfets. My e60 stranded me. But the issue is it can be mosfets or power supply. In my case the mosfets tested fine so wouldn’t have helped
335i e92 TPC 19Ts
03-15-2022, 02:28 PM | #22 |
Rep 5
Posting to get more access to my newbie profile. 2008 e92 335i ~70,000 miles. I had a mosfet issue. My codes were similar and when it went I thought something went in the engine, fairly violent. Got replacement mosfets via digikey via YouTube video suggestion for similar pricing as above and had a local audio repair shop that I take amplifiers to replace them for $60. Less than 10k miles since replacement, still good
with many WOT pulls. |
