03-18-2018, 11:40 AM | #1 |
Rep 832
Drives: 2019 G01 X3
How to polish navi screen and shadowline trim?
Lots of info out there on detailing paint, wheels, glass, interior, etc. -- but what's the best/safest way to polish/correct small scratches and microabrasions on the navi screen (inside) and shadowline trim (outside)?
Also, while I'm here, what do you guys like to use to clean the exhaust tips? I have the BMS tips in black chrome (gloss black). |
03-18-2018, 02:03 PM | #2 |
Rep 7,484
I would look down the Ammo route for plastic polishing:
https://www.ammonyc.com/detailing/ho...rior-plastics/ You have to be very gentle on the nav screen. A small polishing pad on a drill might help if you don't have a mini polisher. Exhaust. Autosol on a power cone with a drill or small polisher. Then add a protective coat like Gtechnq C5 to make cleaning easier next time. |
dr.roro196.50 |
03-18-2018, 02:08 PM | #3 | |
Rep 804
I don't know if I would attempt to mess with the nav screen. You could do more harm then good. As far as the tips, I use 0000 steel wool with a degreaser, soap and water. Just make sure there is plenty of it on the steel wool when washing them. Also, P21S makes a polishing soap that is always recommended on the forums.
dr.roro196.50 |
05-10-2018, 07:38 PM | #5 |
Rep 1,487
Drives: 2108 X3 xDrive30i
I don't know if I would attempt to mess with the nav screen. You could do more harm then good. As far as the tips, I use 0000 steel wool with a degreaser, soap and water. Just make sure there is plenty of it on the steel wool when washing them. Also, P21S makes a polishing soap that is always recommended on the forums.[/QUOTE]
thanks for the vid...good to know... |
05-10-2018, 07:47 PM | #6 |
Rep 1,487
05-11-2018, 02:31 PM | #7 |
A family of bimmers
2757
Rep 7,743
i use a glasses cloth to clean the nav screen very gently. Those things are so sensitive to scratching its crazy.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
