03-26-2018, 06:16 PM | #1 |
Joint Chiefs of Staff
24501
Rep 191,503
GFB DV+ upgrade N20 N55 BMW - IN STOCK!
http://www.extremepowerhouse.com
Why shop with us? Lowest Price Guarantee: We do our best to always have the lowest price on our website, but if you found an even lower price somewhere else let us know. We will match the other price and thrown in an extra $25 store credit towards your next purchase. Financing: We offer 6 months no interest financing. Get the products now, pay later. You can at anytime pay the full amount or make partial payments during these 6 months. If after 6 months, you still have balance remaining on your account there will be a minimum monthly payment with interest applied, subject to credit approval. Customer Service: We offer the best customer service, period! Don’t take our word for it, check out what our customers have to say about Extreme Power House https://www.x-ph.com/customer-reviews/ Hours: We are open 7 days a week from 8 AM to 11 PM Pacific Time. Contact us: For any questions you can pm / email Mike@x-ph.com or call 725-221-5267. If you contact us during business hours, expect a reply within the hour. If you contact us outside of the regular business hours, expect a reply within 6 hours. Chat: Looking for an immediate response to your questions? Go to our website www.x-ph.com and use our chat functionality. Payments: You can make a purchase directly on our website www.x-ph.com or give us a call at 725-221-5267 and we can process your order over the phone. Shipping: Expect to get a tracking number from us same day of your order completion. We try our best to get the products delivered to you ASAP. We ship items using USPS, UPS and FedEx. Contact Mike@x-ph.com for expedited shipping options. Inventory: We stock all the popular products at our Las Vegas warehouse. If item is not in stock, we will get it drop shipped to you directly from the manufacturer’s location. XPH Rewards: We now offer Extreme Power House loyalty points to all our loyal customers. Earn 1 point after every $1 you spend with us. Earn more by sharing our website on social media and referring your friends. Newsletter: Join our newsletter for the latest XPH news, exclusive deals, group buys and coupon codes. We also offer exclusive newsletter flash sales. Order Link https://www.x-ph.com/gfb-turbos-dv-upgrade-n20-n26-n55-bmw/ BMW N55 Engines (ALL) Part No. T9356 BMW N20 Engines (ALL) Part No. T9357 WHEN YOU WANT NO NOISE, NO NONSENSE, JUST PERFORMANCE EUROPEAN MANUFACTURERS ARE PUSHING THEIR ENGINES TO THE LIMIT. GET A DV TO MATCH. GFB’S DV+ DIVERTER VALVE RANGE OFFERS A DIRECT-FIT PERFORMANCE SOLUTION FOR THE WEAK FACTORY DIVERTER VALVES USED ON MANY MODERN VEHICLES. GFB’s DV+ solution couldn’t be simpler - keep what works and replace what doesn’t. Worldwide Patent and Design Patent Pending Retains the factory solenoid coil for seamless integration Replaces plastic valve parts with metal for reliability and strength on chipped engines Direct-fit replacement with GFB’s TMS benefits Exclusive “pilot-actuated” valve mechanism for rapid response at high boost GFB expands the DV+ range with a direct-fit solution for the weak factory diverter valve used on many European vehicles. The solenoid coil itself from the factory-fitted valve is great (the ECU opens it faster than any pneumatic valve so why replace it?), but the weak point however is the valve mechanism itself. So GFB’s DV+ solves this problem by replacing just the valve parts with an anodised billet aluminium housing fitted with a brass piston machined to exacting tolerances. feature-2 Other manufacturers’ products involve replacing the entire system with a traditional pneumatic valve, requiring long vacuum hose runs, additional parts for tapping into the intake manifold vacuum, plus either a different solenoid valve to actuate the pneumatic valve or a ballast resistor to plug into the OE wiring loom. All these additional items result in a product that is slower, less responsive, more expensive and takes much longer to install. GFB’s DV+ solution on the other hand is more responsive, less expensive, easier to install, and doesn’t cause compressor surge/turbo flutter. Oh, and it doesn’t require different springs or frequent re-builds. The DV+ story: Better performance - more reliable Exploded view labels snagit Many late-model European cars use ECU controlled solenoid-type diverter valves. This is a good concept because the valve can react very quickly and it only opens when it needs to. However, there are some problems with these valves. There are typically two types of solenoid-actuated diverter valves found standard on VAG and European cars, both of which have their shortcomings. feature-4 Common OE Problem #1 The diaphragm types are commonly known to rupture, especially when boost and temperature are increased as a result of chip tuning. feature-5 Common OE Problem #2 The plastic piston-type leaks far more than most people realise (by design, not from wear), and doesn’t always close after a high-boost gear shift. Additionally, in both cases, the solenoid on the OE diverter is directly connected to the valve mechanism, which is not ideal because neither it nor the return spring are strong enough to open and close the valve reliably at high boost. With problems like this, you can see why other aftermarket manufacturers assume the best solution is to replace the factory diverter entirely. Unfortunately though, whilst their replacement kits might be stronger than the factory diverter, their slower response speed and lower flow do not justify the extra cost and complexity - more of a compromise than a solution. GFB has taken a different approach to deliver a complete solution that solves existing problems and improves performance, without compromise or a hefty price tag. The DV+ addresses the factory valve problems with a very simple and elegant solution. Keeping the factory solenoid retains all the benefits of the stock system, and replacing the valve parts with indestructable metal components ensures strength and reliability no matter how much boost you run. That's not all. Rather than using the solenoid to directly actuate the valve, we’ve introduced a unique “pilot-actuation” system. This means the solenoid controls the air pressure that is used to open and close the piston, so it doesn't matter how much boost you push through it, the DV+ will open and close reliably without ever exceeding the solenoid’s capability. This feature also improves on the factory system by opening the valve progressively in response to boost pressure, so it only opens as much as required to get the job done (the factory valve simply opens and shuts, it cannot partially open if boost pressure is low), resulting in better throttle response. Unnecessary replacement kits are a compromise, not a solution
04-19-2018, 02:27 PM | #2 |
24501
Rep 191,503
bump
05-14-2018, 06:04 PM | #3 |
24501
Rep 191,503
bump
06-11-2018, 02:41 PM | #4 |
24501
Rep 191,503
bump
07-06-2018, 11:31 AM | #5 |
24501
Rep 191,503
bump
08-02-2018, 06:51 PM | #6 |
24501
Rep 191,503
bump
09-11-2018, 09:30 PM | #7 |
24501
Rep 191,503
bump
10-02-2018, 10:59 PM | #8 |
24501
Rep 191,503
bump
10-18-2018, 10:05 PM | #9 |
24501
Rep 191,503
bump
10-18-2018, 11:34 PM | #10 |
24501
Rep 191,503
bump
10-30-2018, 10:21 PM | #11 |
24501
Rep 191,503
bump
11-28-2018, 10:43 PM | #12 |
24501
Rep 191,503
bump
12-20-2018, 11:19 AM | #13 |
24501
Rep 191,503
bump
01-09-2019, 10:25 AM | #14 |
24501
Rep 191,503
bump
01-29-2019, 06:28 PM | #15 |
24501
Rep 191,503
bump
02-19-2019, 10:47 AM | #16 |
24501
Rep 191,503
bump
03-09-2019, 04:38 PM | #17 |
24501
Rep 191,503
bump
04-01-2019, 09:08 PM | #18 |
24501
Rep 191,503
bump
04-15-2019, 06:32 PM | #19 |
24501
Rep 191,503
bump
04-29-2019, 06:22 PM | #20 |
24501
Rep 191,503
bump
05-17-2019, 11:18 AM | #21 |
24501
Rep 191,503
bump
06-08-2019, 12:13 PM | #22 |
24501
Rep 191,503
bump
