Snap oversteer following understeer on xi?
06-09-2008, 08:36 AM | #1 |
Rep 1,288
Drives: 135i
Hey,
I had an autocross this weekend with BMWCCA and I certainly continue to learn. At the end of the day I dropped three seconds off my time and was pretty competitive with the better street tire cars. But something really weird happened to me on one of the runs. Towards the end of the course there was a big sweeper left turn going into a short chicane left right left followed by a straight. I took it a bit quicker on the sweeper this run so as to allow myself to just hold the throttle on the chicane. So I came into the chicane at a good speed, hit left, right, and then felt a bit of understeer and tried to correct by gently rolling off the throttle and the car jerked side to side and then sent me the OTHER way, tossing me off course... Was this just some freak occurrence that's never happened to anyone? Am I that bad a driver? That happening really confused me.... I mean, I felt that that run the tires were really biting....I don't know if this was caused by me just not being used to the friction from those tire temps or something? Let me know what you guys think. Thanks, Dave EDIT: Some details: Bridgestone Potenza RE-01R 245/45/17 all around, 37 psi rear, 39 psi front, stock suspension all around (until thursday!!!), 85?F ambient temp, 100 octane race fuel
Performance: UUC Sways CDV Mod KW V3 Vorshlag plates Pagid Yellow VK OC Hotchkis Brace STETT IC/CAI Braille B2015 VK Catless DP BMS JB3 M-Tech
#1 Mod: AutoX/HPDE HPDE 3 Many Thanks: **********s UUC Motorwerks VK Motorwerks HP Autowerks SOLD |
06-09-2008, 11:34 AM | #2 |
Rep 201
I haven't driven a XI to the edge so I'm not sure how they would react, however it sounds like lift oversteer.
Lifting the throttle and shifting too much weight forward, especially when the car is rotating could increase the likelihood of the rear snapping around when it loses adhesion. I would have thought that in a XI, you'd want to add throttle when you push to try and get the front to bite. |
06-09-2008, 11:41 AM | #3 |
Rep 5,448
sounds like lift throttle oversteer to me also.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
06-09-2008, 11:43 AM | #4 |
Rep 1,288
Drives: 135i
Oh....that's a very obvious answer isn't it....doh! Well is there any particular suspension/tire adjustment that will lessen the effect of lift off oversteer? Because I know for a fact that if I lifted off at all, it was a minute adjustment and I made absolutely sure to roll off.
06-09-2008, 11:46 AM | #5 |
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Was your DSC/DTC on by any chance?
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
06-09-2008, 11:48 AM | #6 |
Rep 1,288
Drives: 135i
no my DSC/DTC was off, I leave it on in the morning and shut if off for the afternoon.
06-09-2008, 11:50 AM | #7 |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
off throttle oversteer.
Car is now gone .... :-( |
06-09-2008, 11:54 AM | #8 |
Rep 201
Ok, if the throttle change was minor perhapst trying a different entry speed into the chicane might help or trail brake through it and see if that will give you more bite in the front so you can power through with more throttle.
06-09-2008, 11:56 AM | #9 |
Rep 1,288
Drives: 135i
I'll certainly try that next time. I wasn't trying any fancy braking this go, really just teaching myself good positioning and smooth inputs and the like.
06-09-2008, 12:35 PM | #11 | |
Rep 4,380
BTW, longodj, I have considerable experience on track with AWD cars. I have tracked them from late 1997 until probably early 2007. I dont know what you could have done...it is apparent that you upset the car...without being in the car with you at the time..it is hard to tell what might be done to lessen it in the future.
06-09-2008, 01:08 PM | #12 |
Rep 10,509
i'm guessing you were understeering because you tried to carry way too much entry speed into the corner and also had a lot of steering (the wheel was turned a lot) right before you lifted.. when you lifted you unloaded the rear, front tires started to grip as you scrubbed off speed, and then because you still had the steering turned, the car suddenly changed direction in the way the front wheels were turned
hard to say without being in there with you, but perhaps you could try to lower your entry speeds, finish braking earlier and use a neutral throttle at turn in i found this approach was best when tracking my WRX. also have you considered using stock tires for now? IMHO its easier to learn with less sticky tires because the traction limit is reached at a lower speed, making it easier to figure out what is going on and correcting it |
06-09-2008, 05:10 PM | #13 | |
Rep 1,288
Drives: 135i
06-09-2008, 05:15 PM | #14 | |
Rep 1,288
Drives: 135i
I ran my first few autocrosses on stock tires and I might try doing half a day with and half without in the future or something, but I found that the RE-01Rs are street-like enough that they provide the squeally feedback I really need while providing the performance advantage of a sticky tire. Thanks for the input everyone.
06-09-2008, 10:43 PM | #15 |
Rep 5,448
tire pressures?
too much late trail braking snapping off the brakes suddenly more practice being smooth at the limit I too have some decent track experience with AWD cars. in fact I took my wifes 535ixT wagon out once - it was a blast. gave a Caymen a run for his money till she yelled at me for being hard on her brakes. S4to335i - nice collection of Audisa!!! I also tracked my wifes S4 Avant at quite a few events, both Audi club and CCA.
06-10-2008, 09:50 AM | #16 | |
Rep 4,380
I didnt take it as such. From the factory these cars, IMHO, push pretty badly. You can adjust that stuff a bit with tire pressures...but it becomes a chase to find the correct set up as tires heat up. I have autocrossed my 335i only once..but I have lots of experience autocrossing a 2000 Audi S4....actually got third place for the year in 2000 in CSP class in SF Region...with 17 autocrosses attended that year. Anyway, the hard part about autocrossing an AWD car is to get the car to rotate. RWD cars can do this easily. My friend Corey, who now has a 335i..but doesnt autox anymore... spent tons of hours trying to dial in the ability to get the his S4 to rotate...with power. I think this snap oversteer that you encountered was the result of you having understeer..trying to correct for that..and going overboard the other direction. I have spun out in autocross events before.. I know how touchy it can be..especially if you run late in the day and happen to find the marbles/pebbles...I am thinking that these two things could have contributed to your snap oversteer. Anyway, that is my 2 cents worth. Some pictures from 1903...actually 1999 (red A4) and 2000 (blue S4)
Car is now gone .... :-( Last edited by S4to335; 06-10-2008 at 10:56 AM.. |
06-10-2008, 10:53 AM | #17 |
Rep 1,288
Drives: 135i
Thanks for the response, and nice pics! I agree with your interpretation as well I have a lot to work on for either this weekend or next depending on if I want to travel an hour or not...
06-10-2008, 12:30 PM | #18 |
Rep 10,509
slightly off topic, but for what its worth, i use to do a handful of autoX events per year and last year i switched to doing HPDE instead. i find that it is a lot more time efficient. both autoX and hpde use 1 weekend day, but in an autoX you get like 10-12min of actual driving time but in hpde you get anywhere from 80 to 110min of driving. on a $/min driving basis, hpde is also a better value.
you are in rochester? perhaps you can do events at the glen or poconos east |
06-10-2008, 01:59 PM | #19 |
Rep 1,288
Drives: 135i
Hey,
I actually do both. There aren't HPDE events every weekend and even if they are, they are extremely expensive for me. Also, they teach different things I think. Autocross really gets you to act quickly and really be careful about throttle and braking etc. At least so far, it has been a good precursor to HPDE. This year I'm aiming for 4-5 HPDEs and >10 Autocrosses.
06-10-2008, 02:03 PM | #20 |
Rep 1,288
Drives: 135i
Oh and also...in autocross let's say you get 10 min per day at $25 per day that's 2.5 $/min....in HPDE let's say you get 100 min of driving for $250 per day...that's still 2.5 $/min....so really they are equivalent but you're able to do 10 autocrosses on 10 different courses on 10 different days instead of one HPDE on one course. Don't get me wrong I love both, but they have different purposes I think. In terms of adrenaline rush HPDE certainly wins out, but there's also no real competition involved (at my level).
06-10-2008, 04:18 PM | #21 |
Rep 10,509
maybe its different out east.. here in norcal i find that it is possible to do at least 1 HPDE per month, and those are multiple day events, so its possible to get a crap load of seat time in. i hear you on the cost, so i only do average 1 HPDE day per month.
and there are so many technical roads around here its like.. free autoX all the time.. tons of 30mph-60mph roads all to yourself |
06-10-2008, 04:53 PM | #22 | |
Rep 1,288
Drives: 135i
back home in jersey there are tons of twistys but nothing fun up in rochester
Tags |
autocross, bmwcca, racing, snap oversteer, understeer |
