Using a defouler on e90
04-11-2018, 11:40 PM | #4 |
Rep 459
Defoulers will not work, the DME is too sensitive. Besides that, there's not enough room to actually install them anyway.
Keep in mind that the dp-fix is a fiddly thing and BMW uses all 4 O2 sensors for AFR calculations |
04-12-2018, 01:09 PM | #5 |
Rep 449
I agree there is barely enough room for the secondary O2 sensors as is.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C |
04-12-2018, 02:04 PM | #7 | |
Rep 513
Drives: 08 335i
Even if they do work I dont think it would be recommended if you keep them in for any length of time. If the DME is using values from pre / post cat O2 sensors to make calculations on AFR then using the defouler for an extended period of time may cause other issues.
2008 335i E93, DP's, 7" FMIC, DCI,CP TIAL Q BOV, MHD Stage 2+, Alpina Flash
