BMW M2 Forum > BMW M2 Competition Model > Recommended weight reduction for M2 Competition
      04-26-2018, 11:58 PM   #1
DelGriffith
DelGriffith's Avatar
Drives: 2019 SO M2C
Let's start a think-tank.
Many of us are excited to move from the M2 to the M2Comp. I'm sure most track day enthusiasts are disappointed with the 55kg weight gain, all up front. Looking for ideas (on a budget) to decrease the forward weight on the M2Comp. CF hood is an obvious starter, but seems to only decrease by 10 lbs. Feel free to suggest other ways to negate the increases and try to stay near 50/50...
'02 E39 M5-Gone
'07 E60 M5-Gone
'07 E64 M6 Cab-Gone
'17 F87 MG M2-Gone
'19 F87 SO M2C
      04-27-2018, 12:18 AM   #2
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
There are CF hoods offered by Arma Speed and RKP. I couldn't find the weight figures of RKP but Arma Speed says it provides ~20lbs weight savings (9kg vs 18kg). Not sure if I like how it looks though. I will probably wait for BMW to release a CS or CSL model with CF pieces and retrofit OEM parts. You can also go for aluminum front fenders if and when they are available (on CS/L) but not sure it's really worth it.
Btw, there are conflicting weight figures across the web. On BMW Belgium's website, the weight of outgoing M2 is reported as 1570kg 6MT [1595kg DCT] while the weight of M2C is reported as 1550kg 6MT [1575kg DCT].
      04-27-2018, 12:31 AM   #3
hellrotm
Drives: F80
Zero confirmation it is all up front. Willing to bet switching to a dual path exhaust, adding a particulate filter, and the larger dual valued muffler...is defiantly a portion of the weight.
First we need an actual car on some corner balance scales, to get a realistic weight and the weight distribution.
M-Pilot4861.50
fullstack337.50
chmura1558.00
ChrisK4454.00
dmboone254972.00
      04-27-2018, 04:12 AM   #4
allthatisntnow
allthatisntnow's Avatar
Drives: BMW M2C, 991 C2
Yeah the muffler on my 235i weighed a tonne, god only knows what the M2C muffler weighs. Betting thats a good 5-10 KG right there.
      04-27-2018, 01:46 PM   #5
pz619
Drives: F87 M2C 6MT, Tesla 3
I would maybe look at that exhaust. It's quite sizeable.
      04-27-2018, 02:04 PM   #6
Aaaaaaaaa
Drives: The other M3
The M mirrors are probably heavier than the normal ones
      04-27-2018, 08:50 PM   #7
bunnyhive
Drives: m2
i can't handle the truth either
weight gain is somewhat confirmed from BMW official IG
      04-27-2018, 08:58 PM   #8
M3_WC
Drives: M3
No doubt it gained weight, it will be interesting to see an actual car on scales. It is a trade off for the better. Better cooling, stronger block, extra turbo adds weight. Good point above about the exhaust probably being a lot heavier. Even the larger brakes should add a little to weight, but that is for the better as well.
      04-27-2018, 09:08 PM   #9
M-Pilot
M-Pilot's Avatar
Glad they confirmed it. Now I just want to know the weight distribution
      04-27-2018, 10:04 PM   #10
chris719
Drives: '08 M Roadster
I think you should wait for someone to actually corner weigh a car. I am not arguing it will be heavier but many cars esp Porsche have large deviations from posted specs even considering state of fluids etc.
      05-01-2018, 11:06 PM   #11
SEAT TIME RULES
SEAT TIME RULES's Avatar
1105
Drives: 20 BMW M2C 17 Mazda MX-5 RF
2020 BMW M2C  [5.00]
W/O a corner balanced example I would focus on the easy inexpensive diet items. These two are no brainers for me
Order w/o Sunroof
6spd
Rear Seat Delete(professionally done w/ sound insulation)
5lb Antigravity battery
Approx 130-140 lbs weight reduction
Other possibles:
Track Seats w/ appropriate belts
Lighter exhaust
Roof and trunk (expensive!)
Seats would save about 50lbs
200 lbs pretty easy to shed...
2005-2006 BMWCCA Boston Chapter president
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726
x233284.00
      05-01-2018, 11:37 PM   #12
hellrotm
Drives: F80
Order w/o Sunroof
6spd
Other possibles:
Lighter exhaust
Exhaust would be first and foremost(Plus who rolls on stock exhaust these days?). M2C exhaust is going from single path to dual path. Also the dual valve muffler looks much larger and heavier. For example stock M4 exhaust weighs 69lbs. Other exhaust systems can range from 26lbs savings for Mperf to 41lbs savings for BMS exhaust.
M2 single path(stock left)
M4 dual path(stock left)
Also note, some of the deeper tone of the N55 M2 comes from it having a single path exhaust. Active Autowerkes and BMS both make single path exhaust for the M4. They have a much deeper tone than stock.
AA Signature exhaust for M3/M4
BAN_M2C4190.00
norMcal284.50
KevM2724.50
      05-02-2018, 12:28 AM   #13
Yiruna
Yiruna's Avatar
Drives: M2, C63s, 718 Cayman GT4
2018 BMW M2  [0.00]
CSL Trunk from Agency Power
GTS CF Trunk
CF Roof
CF Wing for downforce
Carbon Revolution wheels (Wrapped in Matte Black)
Brembo Ceramic Brakes
Recaro seats (whatever the lightest is)
CF Mirror caps (Might as well with how much money we dropping)
CF GTS Front splitter for frontal down force
Whatever the lightest exhaust is.
Or just have some rich guy send his M2 to Speedkore to develope CF Panels for everything.
2018 MG M2 - Ohlins R
      05-04-2018, 10:56 AM   #14
M1fortyeye
Drives: m140
      05-04-2018, 12:25 PM   #15
Bluenose-2er
Bluenose-2er's Avatar
582
Drives: 2017 LBB 6MT M2
How about switching out the S55 for an N55?
Seriously though... I think the general expectation is that the weight gain is mostly in the front because of the heavier block, heavier cooling system, etc of the S55 and the fact that (the engine) is the only really significant change... as well as the associated exhaust, of course.
Lighter manual seats are a need for both the M2 and M2C.
No Boost4027.00
D22M21373.50
      05-04-2018, 12:59 PM   #16
Drives: BMW M2 Competition
Originally Posted by M1fortyeye View Post
HS is definitely a lighter color than MG.
BOhio175.50
      05-04-2018, 01:13 PM   #17
M-Pilot
M-Pilot's Avatar
IND has some solutions.
BMW MOTORSPORT F22 M235IR RACE TRUNK- Couldn't find the weight saving info https://ind-distribution.com/product?sku=41628417227
EDISON COMPOSITES F87 M2 CARBON GTS HOOD- 11.5kg or ~25lbs weight savings (6kg vs 18kg) https://ind-distribution.com/product?sku=EC-A1008
Edit: Updated links.
      05-04-2018, 02:11 PM   #18
M3_WC
Drives: M3
I bet there is an easy 25-30lbs(maybe more) added by switching from single to dual, doubles everything. Plus the M2C muffler looks as big or bigger than the pic above of the M4 muffler. Also the new particulate filter will add weight to the exhaust. F8x owners have saved some easy weight by going aftermarket.
      05-04-2018, 03:02 PM   #19
M-Pilot
M-Pilot's Avatar
Even MPE saves 26lbs over stock exhaust on M3/M4 so I'm hopeful as well.
      05-04-2018, 04:08 PM   #20
Yiruna
Yiruna's Avatar
2018 BMW M2  [0.00]
BMW MOTORSPORT F22 M235IR RACE TRUNK - Couldn't find the weight saving info
EDISON COMPOSITES F87 M2 CARBON GTS HOOD - 11.5kg or ~25lbs weight savings (6kg vs 18kg)
I'm surprised no one has made M2 door inserts ala M4 CS/GTS. I'd get those for my M2 if it was available.
      05-04-2018, 04:11 PM   #21
RocketBoots
RocketBoots's Avatar
Drives: Horse Drawn Carriage
Diet, exercise, staying away from cheese steaks (although they are so yummy). That could save 50-100 lbs.
Tight fitting leather clothes, puma race shoes, carbon fiber belt buckle; that should get you that extra 10 lbs and 20 hp.
      05-04-2018, 04:30 PM   #22
pal
pal's Avatar
433
Drives: Z4 M Coupe
m2
