05-07-2018, 10:24 PM | #1 |
Rep 2,197
Garage Door Opener?
Hey guys, wondering if we have a garage door opener in our cars?
its in the manual, but not sure if we have it, or how to set it up I have the LCI non-pure
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
05-07-2018, 10:55 PM | #3 |
Rep 2,197
ah ok
any way to retrofit this feature? ive read someone mention frequency differences, but not sure if that rules it out completely or not
05-08-2018, 02:32 AM | #4 |
Rep 1,337
We normally don't have the homelink feature due to the frequency differences in our country however you used to be able to buy a module that sat between the door opener and the homelink that does allow a retrofit of the mirror.
Usually the mirrors are made by gentex and assume BMW use them also. If u are the DIY type then u could always open the remote solder a remote switch to it and route to a unused port on the dash etc
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
Who?484.50 |
05-20-2018, 09:59 AM | #5 |
Rep 1,017
Not exactly what you're after but check out https://flashtoopen.com
I used this on my previous car and it was pretty simple to install. |
05-20-2018, 06:53 PM | #6 |
Rep 1,337
Smiley1175 I don't think u can flash your lights if u have high beam assist. Well I'm pretty sure I couldn't in my 135i
05-21-2018, 04:35 AM | #7 | |
Rep 1,017
I can do it in the M2 and every other BMW (and car) I've driven. Perhaps I've misunderstood what you've said. |
05-21-2018, 04:44 AM | #8 |
Rep 1,337
Ok maybe semantics. Pulling twice (the light stalk - clarifying just in case ) is turning the lights on then off. Older cars a half pull for a flash.
I just seem to remember in my 135i with high beam assist a single pull turned on the assist with no light until it calculated to do so and an A would illuminate on the dash. When it was dark or no on coming cars then the high beams would turn on. Ie: I couldn't flash someone. That was my experience however happy to be corrected. BTW nfi if the M2 has high beam assist
05-21-2018, 08:18 AM | #9 |
Rep 2,197
all g guys, im using my spare garage key that i double sided taped to the door cubby, free, easy and not-visible solution
