05-11-2018, 03:44 PM | #1 |
Rep 1,433
F31 Suspension - Need Feedback on Planned Modifications
I recently picked up a 2017 330i F31 (B46, xDrive) with the M Sport Package and M Adaptive Suspension. I'm aiming to change out the wheels and suspension, and need some input.
Vehicle Purpose:
Goals:
Current Wheels:
Planned Wheels:
Planned Suspension:
Questions:
Much appreciated! Update (5/12/2018): Despite researching this stuff extensively over the recent weeks, it appears that I've overlooked the fact that the Ohlins R & T do not work on xDrive vehicles. Alternatives exist, it seems, but I was very excited to try the Ohlins. This is correct, yes?
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired Last edited by eleven11; 05-12-2018 at 09:04 AM.. |
05-11-2018, 05:35 PM | #2 |
Rep 3,549
Why did you get the adaptive suspension if you weren't going to use it (or did you get this car used)? Seems like a bit of a waste to get rid of it.
Will this car be tracked at all? If you need more camber the options are the -30min (-0.5deg) steering knuckles (~$550 for both), and Superpro camber adjustable bushings (-0.5deg). With the stock components I was only able to get -0.6deg of camber on the front. The track absolutely kills the shoulders of my tires. Swaybars require dropping the sub frames to install them. Lots of $/time for a cheap part. I have shockware on my EDC suspension wagon, and will be putting some Eibach Pro springs on there this weekend and having the Superpro bushings installed next week. Will let you know how it goes. |
05-11-2018, 07:03 PM | #3 | |
Rep 1,433
I might track it in the future, but nothing planned at this time. Every expert I've talked to (Vorshlag, Dinan, local shops, dealership) recommended against springs alone for my goals. They all felt the Ohlins was the best choice. Thanks. Let me know how it goes.
2017 X5M - Current
2017 F31 Wagon - Current 2014 M5 ZCP - Retired 2011 135i Coupe - Retired 2007 335i Sedan - Retired |
05-14-2018, 10:58 AM | #4 | |
Rep 3,549
After putting on my Eibach springs this weekend the wagon rides much flatter with significantly less body roll. With just shockware alone and the stock springs, the body roll was still too much in comfort mode, and I always drove it in sport mode. After the Eibach springs, the car has less body roll in comfort mode than it did previously in sport mode, and interestingly, the gap between comfort and sport modes seems a lot less. |
05-14-2018, 05:33 PM | #5 | |
Rep 1,433
I considered getting Shockwave. However, lowering springs alone will lead to premature degradation of the suspension. I understand what your saying about not tracking the vehicle. Now that I've learned that Ohlins aren't applicable to xDrive vehicles (waiting to hear from them for final verification), I've decided to go with the KW DDC Plug & Play setup.
2017 X5M - Current
05-21-2018, 06:15 AM | #6 |
Rep 227
Drives: 2000 BMW E39 M5
Not sure if this helps, but I installed the H&R rear sway bar on my 2017 M-sport F31. I'm a fairly experienced wrench turner and this one was the single most difficult DIY I've ever done. Still, it was worth the effort because body roll is significantly reduced with slightly less understeer.
The hardest part of the install is figuring out how to get the new bar into position. The larger diameter bar is just enough to make clearances difficult. Lesson learned, don't take the bubble wrap off until it's in position. Mine got pretty scraped up in the process. |
eleven11376.00 |
05-21-2018, 07:53 AM | #7 |
Rep 806
Yeah the ohlins kit doesn't fit, which sucks as I'd have bought it too. I ran bilstien B16s briefly which were nice but had a few issues (too stiff even for me, front cannot go low enough, unfixable noise developed); so I moved to KW v3s which are great, but still not without issue as I have to get the 'spring spacer' for the rear to get them UP to the proper height.
I believe it's only a minor difference in the front shocks between AWD / RWD ... It'd be nice if someone could figure out what's different and get the ohlins to fit. Really they should make the kit, this is probably the 10th time myself included that we've seen "no ohlins for xdrive". I guarantee you will want to do the sway bars. The body roll is still bad. There's not a lot of bracing on the chassis either, it still has that slop feel and doesn't have that nice tightness you'd get from a car that handles well. And it still understeers a bit, but that should be addressable without too much work. My next move is camber plates and the spring spacer. And then a strut bar of sorts, and some other chassis bracing, whatever is available. Poly bushings would also be nice. And I may have to pay a shop $$$$ to install sway bars. Pretty much tear down the entire car... I am not willing to drop subframes on jackstands, I would die. Sweeney921 curious if you could talk a bit about how long it took etc etc |
eleven11376.00 |
05-21-2018, 12:25 PM | #8 | |
Rep 227
newTIS.info was an invaluable resource and very clearly laid out the steps to perform this DIY. It's important to pay attention to the many torque values and notes, because much of the hardware is torqued to yield and thus cannot be reused. Several of the torques must be applied with weight on the wheels, as well. |
eleven11376.00 |
05-21-2018, 01:55 PM | #9 |
Rep 1,934
Rwd suspension will fit xdrive. Couple users on here went and attempted the swap. Suspension parts differ by spring rate for the f30 due to slight weight differences in the vehicle applications. One user used rwd KW his xdrive. You'll be fine. You can adjust for the weight delta with the adjustments on the coils (height and r/c)
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
eleven11376.00 |
05-21-2018, 05:48 PM | #10 | |||
Rep 1,433
2017 X5M - Current
