05-23-2018, 01:37 PM | #1 |
Rep 435
Mechanical Differences - M2C vs M3/M4
Are there mechanical (intake, exhaust, engine) differences between the M2C and the M3/M4 that contributes to the 20 hp variance or is it just in the software tuning BMW wanted to create a little separation?
05-23-2018, 01:44 PM | #3 | |
Rep 7,594
Drives: '19 M2C
The de-tune is just software. Re-Tune the De-Tune
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
Tag18400.00 |
05-23-2018, 01:46 PM | #4 | ||
Rep 1,420
05-23-2018, 02:04 PM | #5 |
Rep 3,622
I have no doubt it is software only. Just by comparing peak hp at peak rpm. M2C is 410hp at 7000rpm, while M3/M4 is 425hp at 7300rpm. Guarantee the curves overlap perfectly, but M2C has a power target and power starts dropping off at 7000.
05-23-2018, 02:13 PM | #7 |
Rep 3,660
Drives: 981 Cayman GTS
Getting an M4 CS tune will be the first thing I'll do after my break-in service!
The following is from another thread and credit goes to CanAutM3 M4 CS in black, M3/M4 CP in red, M3/M4 base S55 in blue: |
05-23-2018, 02:21 PM | #8 |
Rep 3,622
M2C/M3/M4 S55 all redline at 7600(per instrument clusters). Their peak hp at peak rpm is different only due to tune. Turbo motors, they all die off before redline. S55 does mitigate that a little, compared with other BMW turbo inline 6.
05-23-2018, 02:28 PM | #10 |
Rep 181
So in regards to the peak power. Is it restricted by the software, or if it's mechanical and the turbo is out of its efficiency range beyond 7,000rpm?
05-23-2018, 02:31 PM | #11 |
Rep 3,622
05-23-2018, 02:37 PM | #13 |
Rep 2,680
The drive shaft is different so the detune effects are not known yet until we get real world performance numbers aka power at the wheels. I am hoping the shaft is lighter than the steel shaft on m3/4
05-23-2018, 02:39 PM | #14 | |
this is the way
18400
Rep 8,576
M4 wheelbase: 2,812mm M2c wheelbase: 2,693mm Difference of 119mm or 4.69" |
05-23-2018, 02:46 PM | #15 | |
Rep 2,680
05-23-2018, 02:52 PM | #16 |
Rep 3,660
That's because M3/M4 has aluminum hood and fenders, CF roof, trunk, and driveshaft. Yes, I mentioned the CF driveshaft because the M3/M4 weight number that everyone is referring to is from the technical spec sheet that was released years ago when F80/82 first came out (with CF driveshaft). As usual, BMW never updated their specs or released any statement about how much more the 2018 M3/M4 weighs due to the steel driveshaft.
qnet684.50 Cavpilot2k1025.00 |
05-23-2018, 02:53 PM | #17 |
this is the way
18400
Rep 8,576
We're comparing rotational mass of a shorter drive shaft, not overall vehicle weight. It's a good thing in that regard.
05-23-2018, 02:57 PM | #18 | |
Rep 3,622
05-23-2018, 03:03 PM | #19 |
Rep 2,856
Drives: BMW M2 CSL Turbomeister
Mine will go on a really professional dyno as soon as it is driven in, so I can report on that to you guys
MR |
Tag18400.00 Cavpilot2k1025.00 |
05-23-2018, 03:06 PM | #20 |
Rep 3,660
Read about that couple months ago but didn't know it was still happening. In any case, it'd be nice know the weight difference between CF and steel driveshafts. Also curious if this particulate filter deal applies to each and every model in the lineup including the limited edition models. BMW explicitly stated that M3 and M4 CS will continue to have CF driveshaft and I don't think they will stop M4 CS production after June 1st.
05-23-2018, 04:51 PM | #21 |
Luxury at the redline :)
9108
Rep 7,563
I would wait 3 months or so until I'm sure the motor is not a dud before I thrown on a piggyback or tune.. If an engine does not show signs of any factory defects or built by then, then most likely it would run like a well oiled machine during its tenure, IMO. Warranty withstanding.
05-23-2018, 05:05 PM | #22 |
Rep 390
I'd be shocked if it were just a tune that makes the difference.
From the Mini World...2nd Gen. And "S" and highest trim level "JCW" shared the same general engine, but slightly different hardware tweaks that always gave a higher ceiling for the JCW over an S. If it really is as simple as a tune....absolutely stupid on BMWs part...great for the consumer! Just pick up your cheaper M4. |
