2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Heat Soak
      05-26-2018, 04:23 AM   #1
olehead
Drives: 2018 M240I X drive
Heat Soak
Just a fyi for you that are tracking the car -My last track day it was hot (91) and humid (74) I can tell these cars really do not like those conditions at all - you can lose up to 1/2 sec and 4 mph - They are in need of a much bigger intercooler for sure.
      05-26-2018, 10:08 AM   #2
amw896
amw896's Avatar
Drives: 2015 BMW M235i
2015 BMW M235i  [10.00]
That, and the stock charge pipe were the first mods I did on the n55 because of the same reason.
How is the charge pipe on the b58?
      05-28-2018, 08:03 AM   #3
NISFAN
NISFAN's Avatar
Drives: BMW M2
Were you running aircon aswell?
      05-29-2018, 04:42 AM   #4
olehead
you never run Air Condition at track can cause overflow in the prep and launch area
      05-29-2018, 10:31 AM   #5
WolfGTI
WolfGTI's Avatar
Drives: '17 F22,15 E84 M Sport,02 R53
2017 BMW M240i  [0.00]
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
The original post - is in reference to your M235i -- or do you have a M240i ?
      05-29-2018, 11:36 AM   #6
cxp213
cxp213's Avatar
313
Drives: M235i
Yep, these cars heat soak like a MOFO. I also live in TX, though, so that certainly doesn't help.
      05-29-2018, 02:48 PM   #7
olehead
M240I x drive
WolfGTI716.00
      05-30-2018, 01:56 AM   #8
NISFAN
NISFAN's Avatar
Drives: BMW M2
Oh you mean a drag strip.
An intercooler doesn't work when you do 1/4 mile runs then bumper to bumper at walking speed.
Fill your reservoir with ice before each run.
      05-30-2018, 05:06 PM   #9
B58togo
Drives: M240i
What were your IAT’s? I know my car turns into a pig when they’re up around 130, which is where they tend to hover after sitting and waiting to line up.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
      06-03-2018, 04:43 PM   #10
MarcoZandrini
Drives: 2018 M240i
My experiencew is the cooling systems-engine and intercooler-are well engineered. I've done track time at Virginia International Raceway and Summit Point. The oil temperature never got above the normal, on the road reading. The car was strong from session start to session end. And, I pushed him (his name is "Gerhardt") as hard as I could. Hit 135 in 4th gear (manual, natch) on the main straight at VIR and 130mph at SP.
      06-06-2018, 07:40 AM   #11
olehead
I can say that is not true in 1/4 mile racing - and not just my BMW - we made back to back runs on a warm and humid day, with the exact same 60ft time and the ET was down 3 tenths and the mph off 2 mph - In addition it is a known fact that turbo cars perform much better in cold air and low humidity.
WolfGTI716.00
2addicts
