05-29-2018, 10:42 AM | #1 |
Rep 23
Rear aftermarket rotor for F30 328Xi
I'm looking to upgrade my factory rear rotors on my 2014 328Xi.
I purchased the Powerstop EBR1403XPR but it does not fit. Can someone help me which one would fit? I'm looking for a drilled/slotted rear rotor option. My VIN is WBA3B3C50EJ981428. Appreciate any help! |
05-30-2018, 12:00 PM | #2 | |
Rep 285
Drives: 2014 428i XDrive
https://www.r1concepts.com/detail_ca...otor+silver+++ Try here. I just bought a full kit from here for my F32 and from my research they're better than Power Stop. they also have a 15% off coupon. Should be around $100 or so for the rear slotted and drilled. |
molnii481508.00 |
05-31-2018, 04:18 AM | #3 |
No 55mph
1623
Rep 8,479
If you have the std. brakes with Bosch 1 piston rear calipers (not 2 piston Brembo) - then yes, your rear rotors are 300x20
I also recommend the R1Concepts rotors, been using them since 2009 for replacements on all my BMW's The E-Line mentioned above are their budget rotors & not coated - so they will show rust on edges/vanes, holes/slots, & hubs I would go with their R1 Carbon Geomet series crossdrilled/slotted version. Made from much better materials & the Geomet coating is 2nd to none for protection against rust. Coating will wear off in couple days ONLY on the firepath face of the rotors where pads contact. Edges/vanes, inside slots, inside holes/chamfers & most importantly the hubs will remain silver & rust free https://www.r1concepts.com/detail_ca...otor+silver+++ Use these currently on my F32 435 for rear rotors with the MPerf Brembo brakes (different size though) - even thru several winters here in PA with all the road salt = still rust free Still only $152 for the pair with the 15% off & free shipping, & they are a forum vendor Best thing to do is give their sales team a call, explain exact brakes you have - that way there is no way of getting incorrect rotors for your app
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
molnii481508.00 |
06-03-2018, 07:19 PM | #5 |
No 55mph
1623
Rep 8,479
It's now only 13% off
Coupon code on their site DAD2018
06-07-2018, 09:22 AM | #6 | |
Rep 121
06-07-2018, 09:37 AM | #7 |
No 55mph
1623
Rep 8,479
They sell the fronts also - just ask them when you call for correct P/N
I'm using the new ECSTuning 2-pc front rotors at 370mm - I like to put more $$ in the fronts as they do most of the work
06-08-2018, 12:02 AM | #8 |
Rep 285
