E90Post
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > DCI install for $50
Reply
      06-20-2018, 05:26 PM   #1
535XrayIndigo
Drives: 128i
DCI install for $50
Hey All,
I know there are a million of these out there. I just wanted to share mine.
I am not responsible for any damage you may cause performing this service.
Tools:
Flathead
1/4 inch bit bit-driver
Arms
I Purchased all my parts through Amazon:
2 x https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
1:Clean any residue off of the inside of your adapter pipes. I used alcohol and a clean rag for this.
2:Start removing the air box by the clips on top and removing the filter element. (clean any large debris out so they do not fall into your inlet before removal.)
3:Remove Breather and unclip the tube from the airbox that goes over the breather inlet:
3:Loosen Screw Clamps on front and back using a bit driver. (the clamps are 1/4" so no bit need be installed in the bit driver.)
4:Remove rubber cable holds near back of airbox then lift to remove air box:
5:Insert 2.25' - 3' into intake tubing and tighten using bit driver. (confirm they are tight and do not move.)
6:Attach filters and clamp down using Flathead screwdriver.
7: Enjoy!!
      06-23-2018, 10:38 PM   #2
Some Asian Guy
Some Asian Guy's Avatar
Drives: 2015 BMW X5
Thanks for this! I'll probably do it next weekend.
      06-26-2018, 12:21 AM   #3
535XrayIndigo
Drives: 128i
No problem. I don’t love the chrome. That can be pulled off easy enough though. Next is coils, FMIC, hpfp and injectors and all lifetime service fluids, Then tune.
Reply
e90post
