Turbo Seals DIY?
07-17-2018, 12:55 AM | #1 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
Turbo Seals DIY?
I'm taking the down pipes out for a engine mounts DIY soon. I figured while I'm in there, I might as well replace the turbo seals, which have 153,000 miles on them.
Is there a DIY on this. Is there any information I need to know in order to do this DIY? From pics on Google, it looks as if all have to do is run a pick around the edges and pry them out, and then press the new ones in by hand? Any tricks ? Please Advise... |
07-17-2018, 02:56 AM | #2 |
Rep 175
Unless there's some secret I'm not aware of taking out the downpipes will not get you anywhere near the turbo seals. Like saying I'm doing my oil change might as well replace my rod bearings while I'm there.
Edit: unless you are talking about the gasket between the turbos and downpipes? |
07-17-2018, 03:26 AM | #3 | |
Rep 6,968
07-17-2018, 09:40 AM | #4 |
Guest
Rep n/a
Drives:
RealOEM to the rescue!
https://www.realoem.com/bmw/enUS/sho...diagId=18_0681 |
mweisdorfer1906.50 feuer4277.00 |
07-17-2018, 10:16 AM | #5 | |
Rep 6,968
I plan on liberally coating the bolts, which secure the the cats the rest of the exhaust, with Nickle based Anti-Seize. It's rated at 2500 degrees. However, I am wondering if I should get grade 8 hardened steel bolts & nuts. My point is, back in April, I had one hell of a time getting the OEM bolts & nuts "removed" when I originally did the engine mounts. I used BMS gaskets, bolts & nuts set. I ordered two sets at the time. So, I am using set # 2 now. I am just thinking how I could make my life easier when I go back in there, in a couple of years, to do the turbos. I live in Michigan & we use Salt very liberally on the roads, during the winter months Your thoughts...., |
07-18-2018, 11:23 AM | #7 |
Rep 9,209
Salt from the road won't get on the turbos unless you drive around without bottom plastic engine cover. I have done many and only issue are the bolts for dp to exhaust. Rest is ok. My personal 335i was used as test mule for 3 diferent no name dp and gaskets never leaked. So honestly I won't bother with them unless they are leaking and you are 100% they are leaking. Also. No need to remove dp for engine mount replacement. I sure don't do it.
07-18-2018, 06:05 PM | #8 | |
Rep 6,968
I am following this DIY for the engine mounts. http://www.n54tech.com/forums/showthread.php?t=22841 |
07-18-2018, 08:14 PM | #9 |
Rep 50
I installed downpipes not too long ago. I replaced the gaskets but in all honesty, I don't think it's a must. That said, they are pretty darn cheap so why not? Some sort of pick tool will help get a grip on the ring and they should come right out.
