FS/FT: 2007 e90 335xi Manual Sport Pure Turbos
07-25-2018, 06:26 PM | #1 |
Rep 91
2007 335XI 6MT Sedan Sport Premium Nav Cold Weather Grey on Black Parts: Pure Stage 1 Turbos Apex ARC 8 17x9 with MPSS ST X coilovers VRSF Charge Pipe VRSF Downpipes VRSF 7in HD Intercooler Stg 2 fuel pump 335is clutch and new DMFW Twisted tuning tcase mount insert PE mod Recent oil Analysis available Motiv 93 and e50 files Chris @ Motiv estimates 500/500 on e50 Clean title in hand 151k Miles. Purchased at 107k from a BMW dealer in Ohio - maintenance below Battery 109k Plugs 109k Coils 109k Vanos solenoid cleaning 109 Valve cleaning. 110599 Vacuum line replacement 110 Rear brakes 110 Transfer case actuator 110 Transfer case replacement 110 Bank 2 injectors 111k Alternator 112 Oil change 113200 Front brake rotors/pads tire balance rotation 114600 Bank 1 injectors 115k Parking light bulbs 115k Left rear wheel bearing 119k Downpipe to exhaust gaskets 120k Retune 122k Oil change w/ black stone sample 122648 ST "X" coilover install 123k All rear rubber mounts replaced Tire rotation Motor mounts replaced with iS mounts 125k Ac system recharge and inspection 125k Apex wheels with MPSS 127k VRSF 7in HD FMIC 128k Oil change 129k Downpipes 129k Inlets 129k Belt, tensioner, pulleys 129k Coolant replacement 129k Valve cleaning 129k Tension struts replacement 131400 Tire rotation 131400 Front drive shaft 133356 T case mount 133356 Door lock actuator 136k Pure stage 1 turbos 137k Rear main seal Oil change Coolant change 335is clutch Replaced dual mass flywheel Clutch fork Brass pivot pin Transmission fluid change Valve cover and gasket 140500 Switch summer to winter tires 148500 Oil change 148749 Oil pan gasket Oil change Front right axle Front left axle Front diff reseal and service Drive belt Secure front inlet 151000 Lowballs ignored Would trade for a mk7 gti/ E46 m3 Last edited by mikes4; 08-27-2018 at 01:16 AM.. |
01-23-2019, 09:30 AM | #6 |
Rep 140
any more pictures?
I wish I had more room in my garage though... seems like a solid deal at $13k with some excellent mods and maintenance GLWS! |
