07-26-2018, 10:31 AM | #1 |
Rep 1,849
Is this the right engine oil to use ?
Hi guys ,
I had left this can of oil from my X5M. Even though I'm almost sure it's ok , I wanted to have your opinion. Can I use , if needed , this oil for the M5 ? Thank you ! Last edited by Alberta; 10-28-2022 at 09:20 AM.. |
07-26-2018, 10:35 AM | #2 |
Rep 4,532
I would.
Speedwell-Industries434.00 |
07-26-2018, 11:04 AM | #3 |
Rep 1,849
Thank you , Onfire !
07-26-2018, 11:29 AM | #4 |
Rep 593
We use 5W30
435d xDrive & M5 F90 Frozen dark silver metallic |
Speedwell-Industries434.00 PhatLyfe985.00 |
12-29-2018, 07:38 AM | #5 |
Rep 459
I used 5w40 in the F10 M5 which was the recommended grade for warm climates.....since the F90 M5 has the same engine I suspect this recommendation is the same? Anyone have the warm climate grade oil spec?
I found this from another thread "It's the same for F10, pretty much 0W-30, 0W-40, 5W-30, 5W-40, depends on where you are at, but they all ok to use." |
