07-26-2018, 09:40 PM | #1 |
Rep 4
JB4 Install question!
Hello,
I am currently installing the JB4 ON MY 2017 m240 6spd. the install guide from Burger is for a 340i. I am stuck where I need to feed the BMW Cable through the rubber plug in the firewall. Does anyone know where this plug is?? I'm looking in the cowl behind the clutch slave and don't see anywhere to go through the firewall. Help! |
07-26-2018, 11:05 PM | #2 | |
Rep 225
One tip I should mention is use a piece of duct tape on the plug to hold it before popping it out. Otherwise it is easy to have it fall and be gone forever. Not really a big deal, but it is nice to have in case you want to ever take the JB4 out and put the plug back in.
16 M235 Cabrio - BM3, ER CP, Wagner DP & IC, Dinan Intake, MPE, Torqbyte CM5
18 340i F30 mostly stock Last edited by M235SDCA; 07-26-2018 at 11:10 PM.. |
07-28-2018, 01:33 PM | #4 |
Rep 23
I have the manual as well and couldn't just pull the rubber plug out. I had to pierce it a few times with a pick then straighten out a wire hanger and tape the cable to the hanger and push it through. Annoying but it worked fine.
03-30-2019, 10:08 AM | #5 | ||
2018 M240i / BMS CAI / JB4 / Catless VRSF
134
Rep 112
Now, as far as my installation experience, I'm not thrilled at all. Trying to pull the grommet out with the clutch hose was impossible, I was able to push it into the fw but then when I went inside the car, there was a very thick rubber foam mat in the way and only 3/4 inch of hose exposed that connects to the back of the clutch pedal. Needless to say, that didn't happen. So I now have the grommet stuck inside the fw. My work around - I noticed 2, ~ 3/8inch holes alittle below that hose (inside) thats part of the main wiring harness running through the fw. I took a skinny flat head and pierced through and that's how I found out it was the main harness (was not happy at all) but found this to be the easiest way to get the OBD cable through. I had to made the hole a little larger but was finally able to get the connector through. I will take some pictures today and post. My biggest concern is getting that grommet back into place so I don't slice the hose. so I have to get long thing needle nose pliers and see if that will allow me to get it back into place. Hope this helps my fellow 6MT drivers!
Can't stop the //Addiction...2020 Misano M2CS 6MT - New Toy
2018 m240i b58 - Formerly owned / BMS CAI / VRSF DP / JB4 map 2 - 340WHP; 363TQ 2016 328i xdrive n26 - daily 2015 GMC Sierra 1500 - daily driver HEUSING240i |
03-30-2019, 06:29 PM | #6 |
Rep 189
I have a manual as well. I ended up using the grommet to the right of the one that the instructions tell you. I believe it's where the hood cable runs through. Took me 5min to run it through vs the 2hrs I tried on the other.
04-07-2019, 07:45 PM | #7 |
Rep 119
I have the auto and just pushed the rubber plug in from the engine compartment side and it landed on my floor. From what I understand, this hole is where the clutch cable comes through in the manual.
2017 BMW M240i xDrive - Mission Performance Stage 2 and transmission flash, CSF Intercooler, VRSF 4.5" downpipe, Dinan midpipe, BMW M Performance muffler, Agency Power Cold Air Intake. 11.58 @ 116MPH
04-08-2019, 12:49 AM | #8 |
Car Geek
3706
Rep 3,620
There is no clutch cable in a manual BMW, the hydraulic clutch slave cylinder is mounted through the firewall with no grommeted hole needed for the mechanism.
04-10-2019, 09:12 AM | #9 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
thanks for the pic bootmod3nyc lol
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
