08-09-2018, 01:18 AM | #1 |
Rep 95
DSC+Steering Angle Sensor issue
hey guys,
I recently switched out paddle shifters and while taking the steering wheel out, i accidentally moved clockspring. Since then I'm getting DSC and Angel Sensor fault codes. I did recalibrate the sensor by turning the steering wheel all the way to left and right. Fault code did go away but whenever I disconnect the battery it comes back, which never happened before. I'm just curious if this is something I should worry about? How do I center/neutral clockspring again? Do I need to go to dealer to recalibrate it properly? Attached is the screenshot of fault codes on ISTAD Thank you |
10-01-2018, 07:11 PM | #2 |
Rep 57
Is there a way to switch off angle sensor?
Since I added more angle to front, I am constantly getting error when doing full angle drift which only goes away by restarting the vehicle. |
