330D M Sport Engine rebuild Help
06-26-2008, 03:37 PM | #1 |
Rep 6
Hi,
car involved in a flash flood. cylinders 3456 low on compression... is it worth taking the head off and replacing the conrods and looking for further damage. or replace the motor... has anyone got a price of the conrods. thanks |
06-27-2008, 10:00 PM | #2 |
Rep 1,555
Electrical gremlins might make you wish you had totaled the car or replaced it.
Low compression is indicates 1) piston slap or failure of the rings to seal 2) valves that do not seat properly or 3) leaking head gasket. I would recommend a new engine....for peace of mind, however this does not address any water damage to electrical components. No need to replace the connecting rods unless they are out of tolerance. If the head gasket blew (my guess) you might be fine with just replacing it. Good Luck
