BMW M2 Forum > BMW M2 Discussions > Front Bumper Removal
      09-05-2018, 04:23 PM   #1
GregoryK
GregoryK's Avatar
Drives: M2 '18
Just pulled the front bumper and stripped off all the trim. The instructions for doing so are terrible. Trust me I searched.
**** SEE POST #19 FOR FULL INSTRUCTION PDF*****
First off now I know how to do it I could do it very quickly (less than 20minutes) as opposed to the 4 hours it took me to get it off the car without braking anything. The reason for this post is that if you are doing this and have a question send me a PM. Things like removing the headlamp washer HP lines can be scary and tricky. If you are going all out and stripping the trim. vents etc. there is an order that is only learned from mistakes. One side took 2 hours the other 3 minutes!
Reason for removal is I wanted to install a new intercooler and also touch up some marks on the bumper from someone reversing into me!
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo
      09-05-2018, 04:38 PM   #2
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
You should make a DIY instructional post with photos. Would probably be super helpful to many people.
randyt224.50
      09-05-2018, 05:35 PM   #3
akkando
akkando's Avatar
5873
Drives: 17 M2 DCT LBB,11 e90 M3 ZCP IB
Yea that would be awesome.
      09-05-2018, 06:57 PM   #4
GregoryK
GregoryK's Avatar
Drives: M2 '18
Problem is I went into this without thinking that way - so did not take the photos. You guys are right though. Maybe I can do it in reverse.
      09-05-2018, 07:03 PM   #5
ORG
Stripped of Rank
ORG's Avatar
53
Drives: 2018 M2
My first time sucked too. Now less than 30 min, and that's being careful.
      09-06-2018, 05:14 AM   #6
Bt12
Drives: 2018 X5,2018 m2, 2018 x1
Yeah a DIY would be awesome
      09-06-2018, 06:30 AM   #7
Who?
Who?'s Avatar
Australia
487
Drives: F87 LCI
Yeah diy please!
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      09-06-2018, 09:13 AM   #8
eatingpizzainthef87rules
Drives: M2
Thanks for posting this! Have to do this next week
Can you post some protips?
      09-06-2018, 06:10 PM   #9
GregoryK
GregoryK's Avatar
Drives: M2 '18
Rattle can sprayed my bumper with excellent results! Will post a DIY over the weekend.
      09-07-2018, 06:31 PM   #10
911sanantone
Drives: 2018 BMW M2, 2001 330
Any information/tips/hints would be very appreciated.
I would love to change my stock kidneys to black but have not pulled the trigger because of my concerns of time and difficulty to remove bumper and possible damage.
Thanks....
      09-07-2018, 08:42 PM   #11
kfscoll
kfscoll's Avatar
Drives: ‘18 MG M2 6MT, ‘15 MW X3 35i
Thanks....
There’s an IND DIY for that here.
      09-07-2018, 08:58 PM   #12
911sanantone
Thanks very much Easier than I thought. I appreciate it!
      09-08-2018, 03:27 PM   #13
F87_LCI
F87_LCI's Avatar
1789
Drives: 2018 LBB F87
@ OP
What FMIC did you get that requires you to remove the bumper?? Wagner Comp II went in no problem for me without bumper removal. Also changed CP/BP/Inlet same time.
HODLM363.50
      09-09-2018, 06:11 AM   #14
GregoryK
GregoryK's Avatar
Drives: M2 '18
Originally Posted by F87_LCI View Post
@ OP
I did to really have to remove the bumper to install. I had to remove it to do some rattle can painting and heard that BMW recommend you remove the bumper to remove the FMIC. After the whole process it is not necessary but makes it easier because you can see really well and you don't need to jack your car.
I installed a CSF FMIC. Big Turbo is next. Debating whether to do this myself.
      09-14-2018, 04:46 AM   #15
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
I could use the DIY since lidar jammer and remote radar head placement is much easier with the bumper off.
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice.
I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway.
I'm also a fan of aural pleasure.
randyt224.50
      09-15-2018, 03:11 PM   #16
Nezil
Nezil's Avatar
1404
Drives: LCI '18 6MT M2
I don't have any photos, but the ISTA+ description is pretty good if you have that.
I'll try and give a few pointers that weren't that obvious when taking it off myself. It's pretty fresh in my mind because I helped nish4 take his bumper off and put it back on again several times over the last couple of days (long story, I'll let him say why if he wants).
It is by far easier to remove if you have the front wheels removed. nish4 didn't do this, and it didn't make it impossible at all, but quite a bit more annoying and fiddly. This will have the side effect of raising the front of the car a bit as well because you'll have it on a Quick Jack or axle stands, which also helps with the screws underneath.
The second thing that's worth removing is the front inner wheel arch plastic cover. It's held in with about 6 8mm self tapping screws, and when removed, makes it really easy to see inside the back of the front bumper.
The third thing worth removing, is the front lower plastic cover under the bumper. You've got to remove most of the screws (again 8mm self tapping) where they attach to the bumper anyway, so just remove the ones at the rear and pull that piece off. Sliding the bumper on again afterwards is easier if you're not trying to align this piece as well.
Before removing any other screws, unclip the headlight washers and temperature sensor on the drivers side (LHD vehicles). The covers have to be un-clipped from the washers first, which isn't difficult, but a little scary. Use something like a credit card slid under the covers to pull the jets out, and you'll see that they un-clip really easily. Once the covers are off, there are two tabs on the back side of the jets that when lifted, allow the jet to slide out with the piping attached. I have found that there is no need to disconnect the piping and loose the washer fluid, and I've done this a few times now. Just slide out the jets and make sure the piping isn't hooked up on anything behind the bumper before you pull it off.
Once you've got those parts removed, there are 3 long 8mm screws at the top sides of the bumper by the headlights, which screw into plastic brackets sandwiching the bumper to the fender. It's a clever design with moulded pins that also align the sandwich together so you can't really get it mis-aligned when you're re-fitting.
I'd suggest leaving the top Torx screws to last, so that you're not worrying about having the bumper fall off while you're fiddling under the wheel arches for the other screws.
Once all of the screws are out, you've slid out the washer jets and disconnected the temp sensor, you should be able to pull the bumper off pretty easily. There is a pipe going from the passenger washer jet (LHD vehicles) to the driver side jet that's clipped in to the bumper. You can remove the bumper with this clipped in and place the bumper on some towels etc. Then remove the pipe from the clips and it's totally free.
The only other tip I have is that when re-installing, remove the main grills first, and place the center support in the highest position before you start. You can then push down the support easily through the grill hole as the last step. Don't mess up and put this center support on too low or upside down, or you'll have to remove the whole bumper again to get it off and back in the correct highest position.
Best of luck!
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings
      09-15-2018, 10:45 PM   #17
nish4
Drives: BMW M2
I did remove the bumper this week with the help of Nezil. Taking the wheels off would make it a lot easier. I did not have a jack, so I did it without removing the wheels. The three screws holding the bumper and the fender are the trickiest. Make sure that you have a 8mm socket with a very small handle (like 2inch). I had a big one and it was pretty difficult with that. Again if you take the wheels you don't have to worry about this.
Couple of tips while putting back.
1. make sure you put the holder near the kidney grills' in the right direction. I put it wrong way and I had to take bumper off to fix it.
2. if you don't remove the headlight washer piping, make sure its of the correct length.
Let me write up another post on why I did this.
      09-16-2018, 03:24 AM   #18
Saphirschwarz
Saphirschwarz's Avatar
Belgium
1069
Drives: M2
See this post for good tips about fast bumper removal: https://f87.bimmerpost.com/forums/sh....php?t=1524621
      09-20-2018, 08:57 PM   #19
GregoryK
GregoryK's Avatar
Drives: M2 '18
Sorry this has taken so long.
Here's a PDF.. Hope this helps
File Type: pdf BMW Front Bumper removal and Strip down.pdf (1.27 MB, 1301 views)
      09-20-2018, 09:33 PM   #20
Drives: M2
Wow thank you!
      09-21-2018, 03:30 PM   #21
randyt
randyt's Avatar
Drives: 2018 MGM 6MT M2
2018 BMW M2  [0.00]
GregoryK Nicely done.
Thanks.
      10-28-2020, 09:30 PM   #22
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
The PDF link seems to be gone, or for some reason not showing for me. Can someone repost or point me to where I can find it? Thanks!
m2
