09-13-2018, 03:32 AM | #1 |
Rep 50
How about 18' wheel 245 tires all around?
Hi Guys.
Do you think it's a good idea to have 18' wheels 245 tires all around? I saw someone has 245 all around, so I was thinking to buy another set of OEM 18' wheels and put the back wheels in the front, with PPS tires? Not sure if it's good |
09-13-2018, 01:39 PM | #3 |
Rep 5,262
245 on 17x8 et40 works... et42 would be the ideal...
09-15-2018, 01:27 PM | #4 | ||
Rep 50
09-15-2018, 02:29 PM | #5 | |
Rep 3,506
In my experience, the fastest and cheapest way is to engage qualified shops and/or vendors to help you navigate your way through the maze. I say this as someone who over the years and across many BMWs has bought multiple sets that were supposed to fit, should have fit, and I was just sure would fit. My takeaway from those missteps is this: thorough research is your friend. Oh, and don't forget fender-rolling as another tool that can help you get what you want.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
09-18-2018, 01:17 PM | #6 | ||
Rep 310
https://www.willtheyfit.com/ |
10-29-2018, 12:32 PM | #8 | |
Rep 310
UPDATE - just ran 245/35/19 Squared at track
UPDATE: I just ran a square set up at the driving school yesterday and everything was fine. I purchased 18x8" 42 offset wheels and ran 245/35/18 Michelin PSS. Everything worked fine, no rubbing and the square set up had less understeer than the staggered. I do not recommend the PSS for the track, but am using because they were my original street tires and didn't want to throw them away. When these are gone I am replacing them with a Street/Track performance tire from Hankook, Toyo or Bridgestone. |
Unicorn123186.50 |
10-30-2018, 10:57 AM | #9 |
Rep 2,878
Thx for the info, considering this myself for track set. Was that w/ spacers in front, or just by themselves?
Unicorn123186.50 |
11-05-2018, 12:29 PM | #11 |
Rep 37
I'm about to do the same thing. Just purchased two 18x8 436M rears from a staggered set and going with square 245/35R18 all around. I realize there'll be clearance issues in the front due to the offset so I'm also getting 12 and 15mm spacers to account for that.
11-06-2018, 05:19 PM | #12 |
Rep 31
FWIW, I also run a 245/35/18 square setup. I've done multiple track days with no issues. My offset is 40 all around. It helped reduce understeer - the car feels very neutral now.
11-26-2018, 01:27 PM | #13 |
Rep 823
Are you 18x8 with the +40? That's what I'm on and thinking about going 245 up front too.
11-26-2018, 02:26 PM | #14 |
Rep 1,931
MPss in 245 is like a 235 in other brands tires.
You will probably rub in the front, depnds on the offset but a pair of spacers will take care of that. Also if you are dropped, it wont fit in the rear probably unless you drop the sidewall down. On stock ride height, i was able to fit 18x40x235 Nitto 01s which is a wide tire without much rubbing.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
Maynard3857.00 |
12-16-2018, 03:29 PM | #15 |
Rep 1,124
Bryan - When I had my 235i, for track days I ran a square setup on 17x8" wheels with the 245/40ZR-17 Hankook R-S3 (Version 2) SL tires. I don't recall the offset, but it was probable an ET40 all around. No issues with running or clearance with this setup. This was a great setup for several reasons. First, I could swaps wheels and tires front to rear. Also, the Hankooks have a super stiff sidewall, so they don't eat tires like the MPSS. Second, this setup saves about 7-8 pound per wheel. Plus, 17 inch tires are cheaper than 18s. To counter act the inherent front end push of the 235i, I ran the fronts with 2lb more pressure than the rears. I'll see if I can find a post I did several years ago with all of the details. Note - Hankook now has the R-S4 which is an update to the R-S3. I run the R-4s on my M2 and they are a great tires.
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
12-16-2018, 03:37 PM | #16 |
Rep 1,124
Here's the exact track setup I used on my '14 235i: 17" Kosei K4R 17x8 et42 on all four corners with 245/40/17 Hankook RS3s.
