09-19-2018, 10:15 PM | #1 |
Rep 1,209
VBOX Tested: Launch Control vs. No Launch Control
Hey guys,
So something that I never found was what is the real difference in acceleration between launch control and just plain hitting the gas from a start. A lot of hear say and this, but how much of a difference is it really? Well, I found out... 2018 X3 M40i - Stock - 8,760 miles 19'' Rims w/ All Season Run Flats 93 octane (full tank) Temp = 61* DA ~ +85 ft All runs were in Sport+ and traction control off. First 2 runs I did not use launch control, just straight hit the gas. Next 2 runs I did, used launch control to 2100 RPM Last run (#5) I did not use launch control, just hit the gas for a consistency check. Results below - 1. Launch control takes off around .4 seconds or so 2. In terms of car lengths, if two X3 M40i's are racing the one using launch control will be approx. 3/4 of a car ahead of the one not using launch control. 3. We found our answer Launch Control - No Launch Control - Thanks guys, up next will be BMS intake 0-60 before and after results.
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
12
DigiSage143.00 darrylo251.00 pskdude49.50 j1980mac262.50 TxHornX3M40iGuy128.50 BMWZ41914.00 BMWGuySweden192.00 Tradecraft26.50 verysideways958.50 focker155.00 XXX3159.50 IM_ALL_IN57.00 |
09-20-2018, 09:06 AM | #2 |
Rep 135
Very! informative post! Thanks! would love to see the BMS intake install, seems like without boosting there is a loss in torque from what I understand.
09-20-2018, 10:11 AM | #3 |
Rep 340
Your letting off the brake too quick, you need to let it settle in at 3000rpm
Youll notice it slows at 2000 but will keep building to 3k
I see normal people , I'm not one of them
2018 X3 M40i - JB4 2016 X3 35i - JB stage 1 2009 335 e92 - JB4 |
09-20-2018, 10:15 AM | #4 |
Rep 545
Drives: x3 m40i
Nice!
I would love to see the difference between sport, sport+ and comfort by just flooring it 0-60 |
09-20-2018, 12:46 PM | #5 |
Rep 954
09-20-2018, 12:53 PM | #6 |
Rep 340
Launch Control was built to go up to a preset max of 3000rpm, its what its built for.
TxHornX3M40iGuy128.50 MechX3M40i1006.00 |
09-20-2018, 04:20 PM | #7 |
Rep 893
Shocker....building up boost before you take off makes a car faster.....Who would have guessed...lol...
You need to stay on LC longer, you weren't at 3,000 rpm so not at full launch boost. Last edited by ParadigmDawg; 09-21-2018 at 09:51 AM.. |
09-20-2018, 06:35 PM | #8 | ||
Rep 1,209
Have a vid? And not JB tuned?
09-20-2018, 08:16 PM | #9 |
Rep 954
09-20-2018, 08:34 PM | #10 |
Rep 394
I’ve LC’d a bunch of times now and the RPM it eventually settles at seems to be different every launch. Sometimes it’ll get to 2900 or so and other times only to 2400.
09-21-2018, 07:29 AM | #11 |
Rep 1,209
True, but it wasn't which is faster, its how much faster if you re-read
pskdude49.50 |
09-22-2018, 09:42 AM | #12 |
Rep 1,209
Update: held launch control for 5 seconds and could get a max of 2700
Tradecraft26.50 verysideways958.50 |
09-22-2018, 08:12 PM | #13 |
Rep 911
Drives: 2020 X3 M40i
I'd like to know from start using manual Sport+. That is pretty much all setting for launch control - stabilization off, sport+ mode, brake on, hammer throttle then release brake, just like when using Launch Control, only in M mode and shifting by paddle. I tried this today and liked it better than launch control.. though wondered about my time vs. full LC.
11-17-2018, 03:35 AM | #14 |
Rep 154
For those who say you can’t get to 3k rpm have you tried using the cruise control toggle to up the desired RPM? I haven’t tried it yet but you can up or down tick the rpm between 3-3.5.
11-17-2018, 05:24 PM | #16 |
Rep 239
11-17-2018, 07:19 PM | #17 |
Rep 154
It was here.
https://www.bmwblog.com/2017/12/02/v...nch-bmw-m-car/ Could be only true M. I haven’t tried it yet. |
11-18-2018, 02:45 PM | #18 |
Rep 1,209
There is a difference between the DCT and the traditional ZF with torque converter.
I tried the cruise control trick and didn't see any difference in RPM... anyone else try it?
11-20-2018, 08:41 AM | #19 | |
Rep 1,349
Need someone to test on an X5M or X6M to see how it behaves or the new M5 which is running the ZF8 as well.
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
11-20-2018, 07:54 PM | #21 |
Rep 1,209
This definitely has something to do with JB4 I would assume and how it alters the boost/sensors. Although do you see the same with stock airbox?
11-21-2018, 06:01 AM | #22 |
Rep 1,349
The torque converters stall speed will be higher because of the additional torque due to the tune. Its holding capacity hasn't changed so if you add more torque, rpms go up until you add too much and you get slippage.
21 BMW X5 xDrive40i
