BIMMERPOST Universal Forums Off-Topic Discussions Board Driveway DIY
      09-20-2018, 01:04 PM   #1
Bryera
Drives: 320D E90
Driveway DIY
Was just wondering what people have on their driveways. The reason I ask is I have just brought up my front drive. I had slabs down and was thinking of puting 40mm plum slate. I was however a little worried how that'll be on the cars tyres and if they would move about when driving off on to the road as I don't want the slate all over the path ? Any one got stone or slate drive ways and happy or not with it 😁
      09-21-2018, 12:22 AM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I have asphalt driveways which came with the house when I bought it. I do want to do concrete but when I got the estimate they wanted close to $20K
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
Dang3r12483.50
King Rudi13084.50
      09-21-2018, 11:12 PM   #3
King Rudi
King Rudi's Avatar
13085
Drives: Meat Suit
I have concrete but it was damaged when I bought my home. Apparently there was tree where my drive way is amd the substrate wasn't compacted properly. I got an estimate to have it removed and replaced for $7k. Talked the seller down $10k off their asking price because of it.
A friend of mine mentioned that he knows someone who does some of resurfacing with an epoxy but without the substrate being fixed first, I imagine I'll only have future problems with.
Subbing to see others and various options.
Originally Posted by jmg View Post
We're Americans. Leave your logic and science witchcraft out of this! Jesus and guns are all we need.
      09-21-2018, 11:14 PM   #4
King Rudi
King Rudi's Avatar
13085
Drives: Meat Suit
Nice place. How often do you reseal your asphalt? I considered going this route as it will be cheaper and I only plan to stay in my place for another 3 years tops.
      09-22-2018, 01:55 AM   #5
lsturbointeg
I've only been in the house for 2 years now and it looks like the reseal was already done. i'm not sure how long it will last nor do I know when it actually needs to be resealed?
      09-22-2018, 08:48 AM   #6
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
This is driven mostly by local building code. Some areas prohibit asphalt or only allow concrete, etc etc.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      09-22-2018, 10:00 AM   #7
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
I got a quote for $36k for stone driveway to replace a gravel driveway.
      09-22-2018, 12:10 PM   #8
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
My only contribution here is that slate can be very slippery when wet.
jaye9441044.00
      09-22-2018, 12:38 PM   #9
Teufelshund
Teufelshund's Avatar
Drives: 2019 X6 xDrive35i
Asphalt here too. After about 10 yrs, it was time to address the cracks that had developed. A paver recommended filling them with a tar substance (same used on state roads) but warned I'd have dark black squiggly lines on my faded asphalt. He said he thought sealing asphalt was a waste of time and money but in this case he'd apply a couple of coats with a broom to hide the lines. Said I should go over it again in a couple of years. Turned out pretty nice for $2,200.
Also, I've got some slate stepping stones leading to a patio. +1 on the slippery comment. When those things get wet it's like walking on an ice rink. They'll probably be my undoing one of these days.
2011 328i (turned-in); 2012 Z4-28i (traded); 2013 X5-35d (traded); 2014 228i (traded); 2015 X5-50i (traded); 2017 X1-28i (traded); 2018 X1-28i (traded); 2018 330i(current); 2019 X6-35i (current)
      09-22-2018, 12:42 PM   #10
Teufelshund
Sorry about that. First attempt to upload an image using the forum app. My house is actually built on top of level ground.
      09-22-2018, 04:23 PM   #11
overcoil
Drives: M235i 6spd
The original poster is in the U.K. ?
I think they do stone and slate much better there then in the U.S..
      09-22-2018, 07:32 PM   #12
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
Look into a concrete leveling company if you haven't already. They pump some kind of concrete slurry under the slab to fix issues like that. Much cheaper fix. Be careful with resurfacing, never seen it hold up well and always has to be redone with just a new slab. Like someone else said, it's slick, same with stamped concrete...worse stuff ever in winter.
King Rudi13084.50
      09-23-2018, 12:18 AM   #13
paliknight
fuck this field
paliknight's Avatar
Drives: 18 F80 CS/18 F80 ZCP/19 M2C
Concrete is irritating. All three of my houses have concrete and developed cracks after 4 years.
BMW family... for now.
      09-23-2018, 01:59 AM   #14
Our03z4
They never make the pour deep enough and the base is a joke. The way they do drives is only adequate for walk ways. New house are horrible in general, I work around them all day every day and everything is rushed and done as cheaply as possible.
      09-23-2018, 02:08 AM   #15
paliknight
fuck this field
paliknight's Avatar
I figured they half as and cheap out on the job. It looks real trashy when you see grass/weeds growing thru the concrete.
      09-23-2018, 10:51 AM   #16
Alvinized52
@ste4lthedF82
Alvinized52's Avatar
Drives: 2016 M4 SSII
2016 BMW M4  [10.00]
I had redone my driveway a while back by a reputable concrete/mason buddy. He said most dont do it deep enough to save money. He said concrete flooring should be minimum 4inch depth for most application... but driveways should be 6" min to withstand weight. Also there should be expansion gaps every so many feet to prevent cracking.
2016 Satin SSII M4 (Instagram: @Ste4lthedF82)
see my featured mods below...
http://f80.bimmerpost.com/forums/sho....php?t=1197842
paliknight2206.00
      09-23-2018, 01:44 PM   #17
FlaPatsFan
Drives: 2011 328i wagon
I replaced my cracked concrete driveway last year with pavers. Love the look and price (5500.00) was about same as redoing the concrete. Sealing it is a PIA but worth it. Cars look great parked in the driveway now and it definitely upped curb appeal and home value!
      09-23-2018, 03:45 PM   #18
RickFLM4
RickFLM4's Avatar
Drives: M4
I have pavers like most others in FL. They look good and don't need to get sealed that often but they do require cleaning and weed grow between them. Also, trees roots can screw them up and if not installed properly they can sink in some stops and need to get re-leveled.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      09-23-2018, 05:31 PM   #19
Slaney
Drives: 2019 M2C
Look up Uretek. They inject foam under the concrete to stabilize. Drill little 1/2" holes as necessary for access. They can lift flatwork using this method as well to level up panels to one another.
      09-23-2018, 06:21 PM   #20
gooselee
Drives: 2019 M550i
We just built a new house and local code required that a portion of it remained permeable (due to land coverage of other structures). The main driveway is concrete but there are two strips cut out of it which we filled with slate chips - they are positioned so that our cars "straddle" the slate areas when driving up the driveway.
Vehicles are primarily meant to stay on the concrete but occasionally we will hit the slate and delivery trucks drive through it all the time. About 1 yr in and so far no issues with the concrete (cracks have properly been kept to the expansion joints). The slate areas are standing up well to the occasional traffic but the chips do move around a bit and our yard man just sweeps/blows the stray chips back in every time he comes by.
As our driveway slopes down toward the street we do have a few steady chips make their way out to the road every so often, especially in heavy rain. I'd guess that we would need to "top off" the fill every other year or so, but more for leveling/anesthetic than maintaining structure. The contractor did cheap out with a 4 in concrete pour but that means the slate is just as deep.
      09-23-2018, 11:46 PM   #21
P1
P1's Avatar
11766
Drives: 2004 3/4 ton Duramax
I used to have 1" river rock which was super easy to put down myself, but did require constant care since weeds would start growing frequently.
Now I have this. Zero car, but just a power was every year or so:
      09-24-2018, 09:25 AM   #22
Bryera
Drives: 320D E90
Sorry for the late reply guys had my phone stone. See a lot of US use concrete or tarmac I looked at that but would of cost a lot more and trying to keep the cost down as I am extending the back so why I am going to be doing it in 40mm plum slate how come you guys from US don't us stone drive way much any reason?
