09-21-2018, 09:33 PM | #1 |
Rep 93
Spare wheel.
So... if you go with aftermarket rims and non-RFT, what do you carry for emergency?
Can my G01 hold a compact spare wheel under the trunk floor? Edit: got the answer about 3" higher floor option from the factory is not possible to be retrofitted. I guess a pump and sealant is my next option. Last edited by RegieX; 09-21-2018 at 09:52 PM.. |
09-21-2018, 09:56 PM | #2 | |
Rep 152
09-21-2018, 09:59 PM | #3 | |
Rep 1,367
The spare tire fits in the boot but it has a cover over it that raises the floor 3.5 inches. You lose about 2.7 cubic feet of space and it looks somewhat odd. |
09-22-2018, 02:41 AM | #4 |
Rep 69
A trunk swap is definitely possible, even by the dealer or a shop. My dealer swapped out a trunk with the spare wheel option to one without. All parts came directly from BMW.
09-22-2018, 09:13 PM | #6 |
Rep 294
I was browsing BavAuto today to see what they had for our cars and noticed a spare-tire kit was available, but it doesn't have all the pieces needed for a full conversion.
https://www.bavauto.com/bmw-spare-tire-kit-b36000203 |
09-23-2018, 12:10 AM | #7 | |
Rep 6,121
Drives: 2022 Porsche Boxster GTS
09-23-2018, 07:08 AM | #8 | |
Rep 969
09-23-2018, 09:43 AM | #9 | |
Rep 294
09-23-2018, 02:03 PM | #10 |
Rep 100
I've been looking into this for a while, I just bought an inexpensive 20" wheel and mounted one of my original front tires (245/50/R20) on it. I swapped the original tires for A/S ones, but need to keep them anyway for lease return. Note that a 20" full-size wheel takes up most of the trunk space, I only carry it when driving through remote areas.
If you want to build the OEM spare tire: The spare tire - $116 from tirerack https://www.tirerack.com/tires/tires...8TEMP&i1_Qty=1 Alternatively the spare tire is sold by getbmwparts as well ($132) - https://www.getbmwparts.com/oem-part...18-36112210357 The wheel itself - $209 - https://www.getbmwparts.com/oem-part...-1-36116863416 Valve - $4 - https://www.getbmwparts.com/oem-part...em-36121116326 Total will easily end up around $350 including shipping. Last edited by frank23; 09-23-2018 at 02:08 PM.. Reason: URLs corrected |
11-05-2020, 12:16 PM | #11 | |
Rep 1,374
Do you recall the cost? Is the same large lid used, so it's the trim pieces arounf the edges / underneath etc that need changing? Thanks
Previously:
2007 Alpina D3 Saloon, 2010 Alpina D3 Biturbo Saloon, 2014 335d XDrive M Sport+ Touring. Now: 2018 Volvo XC90 T6 Inscription Pro 2003 Honda S2000 |
