FED UP with my 2006 E90 sunroof
07-02-2008, 01:15 PM | #1 |
balllllllllin
20
Rep 173
I've been having issues with my 2006 325xi Sedan's sunroof. When I press the button to close it - it closes half way and then opens up again.
I've brought the car in FOUR times already - and it still has not been completly fixed. What would you guys do in my situation? Oh yeah, I've also brought this car in for other issues like the door handles, airbags, tires, radio, etc...I'm real sick of this...
07-02-2008, 03:08 PM | #2 |
Rep 167
There are a couple of things you can do, you can ask and speak to a service manager or request to have a bmw factory rep to look at your car since this is your fourth time.
No one should have to go through that. If it is the same dealer that's working on your car, make sure to get a service director involved. If problem still persist, be sure to also contact BMWNA to file a complaint. Have you also tried a different bmw dealership? That might be another option as well. Good luck to you. |
07-02-2008, 06:28 PM | #3 |
Lord of the Rings
86
Rep 470
Drives: 20 Audi SQ5,05 BMW 330i ZHP
Garage List 2021 BMW M2C [0.00]
2020 Audi SQ5 [0.00] 2019 VW Golf Alltrack [0.00] 2018 Ford F150 [0.00] 1977 VW Scirocco [0.00] 2005 BMW 330i ZHP [0.00] 2007 Audi RS4 [0.00] |
SOunds like the Sunroof Switch is bad and/or the rails need lubricated. I had the exact same problem on my Audi S4 and Passat W8. Both times it was a bad switch...
Cheers, Chuck |
07-02-2008, 06:58 PM | #4 |
I love the ///M3, but I want 550hp ///M5
141
Rep 3,276
Drives: BMW330iE90
do you try to pull the sun roof shade while the sunroof is closing? if so.. dont. Just wait till it closes then pull the shade.
07-02-2008, 07:23 PM | #5 |
this is the way
18455
Rep 8,588
07-02-2008, 07:28 PM | #6 |
Registered Sex Offender
573
Rep 4,759
i know someone who had a problem like that. he took it in thrice (?) and it didnt get resolved so he just gave it back for another one
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
07-03-2008, 01:20 AM | #8 |
Rep 671
Same issue happened to me, my dealer replaced the entire sunroof assembly under warranty. Now I can tilt my sunroof without having the shade retract 1/4 of the way
2011 328iT M-Sport - 6MT
07-03-2008, 06:46 AM | #9 |
balllllllllin
20
Rep 173
Did they give him a new car?
07-03-2008, 06:47 AM | #10 | |
balllllllllin
20
Rep 173
07-03-2008, 12:22 PM | #11 |
Lord of the Rings
86
Rep 470
New switch or sunroof cartridge sounds like the fix....
Cheers Chuck |
07-03-2008, 12:33 PM | #12 |
balllllllllin
20
Rep 173
My cartridge was just replaced - issue still happening!
07-03-2008, 01:53 PM | #13 |
Friends don't let friends apex early
Rep 57
Drives: 2006 E90 325I
Had a similar problem here took it in I believe it was 3 to 4 times as well. Replaced the entire system and then it still kept doing it and finally I don't know what they did but it stopped. Not completely mind you, it happened once more since the repair. But otherwise it's fine. I even contact BMWNA cause apparently no seems to know what the issue is. Hope they figure it out.
07-08-2008, 05:53 PM | #14 | |
Rep 94
BMW NA Customer Relations
07-08-2008, 05:59 PM | #15 |
balllllllllin
20
Rep 173
I've contacted you guys many times and you've offered no help to me at all.
07-10-2008, 06:38 PM | #18 |
Powered By 36DD
341
Rep 7,369
Sorry to hear about your problems man.........
I'm sure you knew what you were getting into when you bought a BMW. I took my car to the dealer for 6-7 issues......good thing we have this thing called WARRANTY. I don't know what I'm going to do in about 3,000 miles when my Warranty expired....... BMW needs to hire some quality control freak to check their products........
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
07-10-2008, 06:43 PM | #19 | |
Rep 9,788
07-10-2008, 07:48 PM | #20 | |
balllllllllin
20
Rep 173
07-10-2008, 09:48 PM | #21 |
Rep 5,842
Drives: 2006 325xi
damn, ya this happens to mine a lot too!!! it stops closing once it starts to press down the wind deflector. I guess i will try to spray some wd-40 in the track, if not i'm calling to get it replaced under warranty before i hit 50k
07-11-2008, 09:48 AM | #22 |
Rep 370
this happens to my 06 e90 also.......
i thought it was anti-trap, but i started putting my hand on the glass and pushing back as hard as i could and it kept on pushing, so it's not that. it has made me wonder if the sensor is bad? usually a sensor for anti trap would measure the voltage for the motor - more amp draw = more resistance or something. i'm past my 50k miles, but i have an extended warranty (3rd party, not through bmw) and the fine print is really unclear, but i think is attempting to say that it only covers the motor for the sunroof. i havent followed up past that. |
