E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Tracking, Autocrossing, Dragstrip, Driving Techniques > how many miles are on your track car?
Reply
      09-24-2018, 09:22 AM   #1
pjr710
Drives: 335i
I'm not 100% an expert on tracking and hard use. I baby my car .. but i do daily it I have 117k on it.
At some point I may turn it into a race car (either drag or track). I'm wondering if mileage is a concern?
      09-24-2018, 06:53 PM   #2
ricardofors68
ricardofors68's Avatar
327
Drives: '15 F10 M5
I have 115k on mine, will be doing rod bearings and walnut blasting. Wastegates are not rattling yet, so I'll give it hell until it does.
Both the bearings and blasting are being done as preventative measures as I have not had any indication of malfunction.
'17 C7 Vette GS (bye) / '15 F31 328 ix (sold) / '08 E92 335i (sold)/ '08 E92 M3 (RIP)/'01 M5 (sold, sniff)/'07 M5 (sold)/ '15 M5
      09-24-2018, 08:30 PM   #3
pjr710
Drives: 335i
that's killer .. can't believe u don't have wastegate rattle.
i keep asking myself what can fail on these motors ... aside from doing preventative maintenance and stuff just trying to figure out what could really kill it as long as you keep taking care of it.
      09-24-2018, 09:07 PM   #4
ricardofors68
327
Drives: '15 F10 M5
Lack of preventative maintenance is what kills BMW engines for the most part, gradually replace plastic parts with metal ones like the radiator.
      10-03-2018, 04:48 PM   #5
minaret
Drives: 2008 E91 ZSP
Recommend contacting Blackstone Labs for an oil sample collection kit. Commercial and Military aviation have used oil analysis for decades to monitor engine wear. Blackstone can also recommend oil change intervals based on your oil analysis. FWIW, I have 265,000 miles on my 2008 N52. I’ve done 25 track days during the past two years.
2008 E91, ARC-8, 255/40/17 NT01, ER sport cooler, TCK camber plates, coil-overs 400# front 700# rear, Koni SA shocks. M3 Subframe bushings, front + rear control arms, tension struts, strut brace. Quaife, Carbotech, Schroth.
      10-08-2018, 03:02 PM   #6
pjr710
Drives: 335i
I love hearing that.
I have been researching a lot more about this topic. Previously I just believed engines could just "blow up" at a certain mileage ... now i'm trying to figure out what actually wears on a motor.
I can understand failure when a component fails or if something gets into the motor.
      10-10-2018, 01:20 PM   #7
slides
Drives: 07 335I
Stock at 68k with 4 track days on it, in the last 20k miles i have replaced the following.
OFHG, oil pan gasket, walnut blast, plugs/coils, waterpump, thermostat, HPFP.
Im hoping nothing else brakes in the next year or so, debating a dinan tune since they are only $600 now or upgrading to an M with better suspension.
      10-13-2018, 11:54 AM   #8
drunkenup
Drives: 2009 135i, 2021 F150
86k on my 135i. 10 days over 2 years, car just spun a bearing on it's 11's day. May have been user error with a recent install, but tracking at my mileage I would have rod bearings and oil analysis done. While the pan is out a baffle is also a good idea.
N54s should add a oil pressure gauge. N55 has oil pressure monitoring out of the box and can be logged on MHD.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
      10-14-2018, 10:46 AM   #9
pjr710
Drives: 335i
how bad was replacing the oil pan gasket?
what causes a spun bearing? and how do you know you spun it? ... would you recommend the n55?
      10-26-2018, 12:39 PM   #10
slides
Drives: 07 335I
It wasn't bad since my extended warranty covered it. I think i paid a couple hundred bucks at the time since they didn't cover the oil filter and oil and a few other random bits there needed to be replaced.
I was very hesitant to get the extended warranty but it has saved me a lot of money, im probably one of the few success stories.
Reply
e90post
