09-25-2018, 01:31 PM | #1 |
Rep 8
H&R Springs for my F30?? Help!
Hello!
I have just fitted my 20" OEMS 115 wheels to my BMW 320d. Now I need to lower it.. but I don't know how much I need to lower it. I have the m-sport chassi so I have heard that its more lowered than regualar f30 chassi from factory.. is this true? I want the car to be lowered but still drivable as its a daily.. Excuse me for my bad English as I am from Sweden. |
09-26-2018, 03:20 PM | #2 | |
Rep 111
Eibach springs drop from stock ~3cm in front and 2.5cm in back. If you have Msport suspensiom then you are already 1cm lower than stock. What is your wheel offset? |
09-26-2018, 03:34 PM | #3 |
Rep 435
I'm on H&R Sports + Bilstein B8s. Also have 20" Velgen VMB5s with 245/35 - 275/30 tires.
The back never rubs but the front sometimes will rub if I hit a bump at high speeds. Other than that, I'm loving the ride quality and setup so far.
2014 335i 6MT /// Mineral Gray - Red Coral
| M Perf Spoiler | M Perf Lip & Diffuser | M Perf Grilles | M Perf Side Splitters | M Perf CF & Alcantra Interior Trim | | Wagner Evo II FMIC | VRSF DP | AA CP | CTS Turbo Intake | MHD Stage 2 Tune | H&R Sports | Bilstein B8s | |
10-17-2018, 07:28 AM | #4 |
Rep 27
The H&R kit (not the ultra low) will drop the msport one by a further 15-20mm
https://mp-uk.com/bmw/3-series/f30-f...le-load-02-12/ |
10-21-2018, 01:04 PM | #5 |
Rep 126
I also have H&R sports with Bilstein B8's and this was a good combo for stance, handling, and comfort for me. As other have said, this setup will drop your car another at least another ~15mm from your M-sport suspension.
10-22-2018, 05:21 PM | #7 |
Rep 3,622
AC Schnitzer springs are awesome
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
11-21-2018, 11:14 AM | #8 |
Rep 8
Hi guys!
Im trying to buy me some H&R springs now BUT.... I ordered from BMW the sticker that's fitted inside the door where you can see all the weights of the car and its says... Permissible Total Weight: 2005 Permissible Front Axle Weight: 1215 Permissible Rear Axle Weight: 980 Front Axle Weight 1215 kg!! And I have been in contact with H&R in Germany and they say that they have no spring to sell to me as me car has a front axle weight of 1215 kg and the springs they have are from 921 kg to 990 maximum. They have never ever tried fitting the springs on a F30 with 1215 front axle weight. Is there anyone here with the same front axle weight as me? How did you do? Regards, STCCEdition |
