HELP!! Disconnected battery and can't get in the trunk!
07-04-2008, 01:44 AM | #1 |
Rep 334
I hope someone can help me....
I disconnected the battery from the trunk to change my steering wheel and closed the trunk. I tried to get back into the trunk using the key. I turn the key but nothing happens.....how the hell do I get into the trunk?? Is there a secret way? Please help!!!!
E46 Retired....................................Project E92 SB 335i
07-04-2008, 01:48 AM | #2 |
Rep 133
can't you hook up a battery to your jumper ports under your hood as if you were going to jump start your car. that should give you power to open the trunk
07-04-2008, 03:08 AM | #5 | |
Rep 6,750
That would probably work, but the key is easier. |
07-04-2008, 08:05 AM | #6 |
Rep 2,373
yea the jump point works, yes the key works you just need to twist it to the left i think..and you should be able to get your seats down from the inside too cant you? hell i forget! haha
07-04-2008, 08:19 AM | #7 |
Rep 2,132
Drives: FBO+ N54xi
hahah shit! same shit happened to me, but thank god the ARM REST comes down and i have winterpackage and theres a hole in there so i grab a L shaped stick and i pulled on that Yellow/Neon handle to open it.
JB4+usb | P3 Vent Boost Gauge v2 | BMS OCC | BMS DCI | AMS FMIC | AR xi CL DP's | BT Tool | Edibias/NCSExpert/INPA BMW Coding | Cyba Quad Exhaust tips | M-Tech Rear & M3 Front Bumper | Red Cyba Air Scoops | Blacklines | Vinyl Overlays | ACS Roof Spoiler | Matte Black Grilles | LED Side Mirrors | Rear Euro Fogs | etc..
07-04-2008, 10:09 AM | #9 |
Rep 1,165
Yeah I thought you just unlock with the key in the keyslot near your rear plate, then push the keyslot in with your thumb to unlatch???
2020 X3 X-Drive 30i; Alpine White/Mocha
07-04-2008, 10:18 AM | #10 |
Rep 6,750
No need to push the keyslot. You just gotta twist it real hard and it will feel as if you're about to break your key.
07-04-2008, 10:21 AM | #11 |
Absolute0
169
Rep 5,078
the seats dont fold down unless trunk is opened. key should work
To procede or not to procede......
07-04-2008, 10:38 AM | #12 |
Rep 167
07-04-2008, 10:40 AM | #13 |
Drives Smart
54
Rep 2,393
As everyone said, twist harder with your key
08 BMW ///M5 Space Gray/Black 6 speed Engine: RPi GTS exhaust, RPi Scoops, Carbon Filter Delete Exterior: Glossy Black Kidneys, LUX V3, OEM LED License Plate light, Bruce License Plate Adapter |
07-04-2008, 11:01 AM | #14 |
Rep 5,271
+1 you need to go to the gym more often
2006 330i | Black Sapphire Metallic | Step Auto | Navi with iDr | Sports Pkg |OEM Rear Spoiler | 3M CS35 Tint | H&R Sport Springs | Koni Yellows | Advan RS Racing Hypersilver: 19x9 et22 19x10 et20
07-04-2008, 11:06 AM | #15 |
Rep 334
Thanks everyone....I couldn't twist the key hard enough with my hands. Used a pair of pliers to twist the key. Man....I can't believe BMW made it so hard to open the trunk with the key. It was so easy with my old E46. Thanks again!
07-04-2008, 12:38 PM | #16 |
Rep 6,750
[u2b]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/WMsxGfACAfo&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/WMsxGfACAfo&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/u2b]
[u2b]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/-hE0vlBCzCU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/-hE0vlBCzCU&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/u2b] |
