10-11-2018, 02:13 PM | #1 |
Rep 739
Plenty of power stock but... I'm already getting the itch!
Anyone have experience yet? Curious to know how it affects drivability as well. |
10-11-2018, 04:28 PM | #2 |
Rep 3,660
Drives: 981 Cayman GTS
I'll do it after my break-in service late November or early December but I have a feeling traction will be an issue with the narrow stock tires on the M2C (245 front 265 rear). I enjoyed my stock M4 Comp more after I replaced 285 rears with 295s. Even though it was a 10mm increase, it made a nice difference in terms of traction. Once my PSS are dead on the M2C, I will do the same and put 265/30/19 front and 295/30/19 rear PS4S tires to take better advantage of the CS tune
COChris888.50 Die ///M Rakete671.00 |
10-12-2018, 03:31 PM | #4 |
Rep 3,660
TUNEDM360.00 AndrewC198910932.50 |
10-12-2018, 06:28 PM | #6 |
Rep 231
I inquired about it, they haven't tested on the m2c yet they said. Pretty small premium for warranty that can be performed at the dealer. Mine is getting parked in two weeks so got some time to wait
10-13-2018, 12:38 PM | #7 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
When I got my M3 ZCP, the CS map was the first flash i did
I highly recommend it as your first map as well!
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
10-13-2018, 06:28 PM | #8 | ||
Rep 4,551
Drives: 2015 328d xDrive
If you just brought it in for an oil change or routine maintenance and it wasn't hooked up it would be fine, and if you flashed it back to stock before any warranty work you'd presumably also be fine...but it's still a risk regardless. There's no 100% guarantee that they wouldn't be able to detect that you've modified the DME. If you're not comfortable risking your warranty don't flash the car. Plain and simple. |
NYC Bimmer259.50 FSociety3812.50 |
10-13-2018, 07:01 PM | #9 |
Rep 806
Drives: 2016 lci m3 mw
I was thinking about this too.. m2c with cs map / cup2s is going to be insane.
f80 m3 lci mw
10-13-2018, 11:10 PM | #10 | |
Rep 3,714
FSociety3812.50 |
10-13-2018, 11:43 PM | #11 | |
Rep 4,551
You asked if bmw would void your warranty if you do a factory CS tune on a M2c and the simple answer is yes, they would. |
NYC Bimmer259.50 |
10-14-2018, 02:57 AM | #12 | |
Rep 6,926
- Revert back to Stock and locked. No chance of tamper code showing once flashed back. - No flash counter limitations - our dev cars have been flashed well over 1000 times. This has always been a BM3 feature. - Flash date freeze - unique BM3-first feature, no other tool supports today. Flash date never changes when flashing with BM3. - Flash counter freezes after OBD unlock But if BMW wants to dig hard enough they can find anything. It would just take a lot more effort. Looks like Steve Dinan will have a stage 1 flash with factory matching warranty. For individuals that want too worry less and not deal with removing tune for service. |
FSociety3812.50 |
10-14-2018, 08:28 AM | #13 | |
Rep 4,551
I haven't heard of them breaking encryption on the F series and everything listed on their website currently is very JB4-esque If they were to come out with a stage 1/2 flash I'd be VERY interested but this piggyback shit is a no go for me. |
NYC Bimmer259.50 |
10-14-2018, 08:34 AM | #14 |
Rep 231
Flash with warranty. Carbahn is the new company
10-14-2018, 09:01 AM | #15 |
Rep 4,551
Got any related links? I googled it and came up empty. Their website doesn't mention anything either.
NYC Bimmer259.50 |
10-14-2018, 12:12 PM | #16 | ||
Rep 6,926
https://carbahnautoworks.com/product...e-f80-f82-f83/ 550 HP/562 TQ (with factory matching warranty) |
10-14-2018, 06:21 PM | #17 | |||
Rep 1,014
Drives: Porsche GTS 4.0
10-14-2018, 08:17 PM | #18 | |
Rep 496
10-14-2018, 08:49 PM | #19 |
Rep 1,759
I am not comfortable with their version of 'warranty' as they will only step up if you can prove that it's their tune that cause the drivetrain issue. Otherwise you are caught between a rock and a hard stone when both of them deny responsibility.
M-Pilot4860.50 NYC Bimmer259.50 |
10-14-2018, 09:51 PM | #20 |
Rep 4,551
I'm no expert but based on everything I've read over the years and based on testimonials of others here, my understanding is that if you tune the car they flag it. If you then bring the car in for a related warranty repair they can deny the claim if they prove it was related. If I'm wrong then please fill me in.
NYC Bimmer259.50 |
10-15-2018, 01:18 AM | #21 |
Rep 7,315
10-15-2018, 06:04 AM | #22 |
Rep 496
Yes, all they could "flag" is drivetrain and if you really wanted, you could lawyer up and have them prove the tune was at fault... its typically a losing battle though, because of the obvious lawyer fees
All warranty work I've ever gotten on my cars (including a new motor and trans..) was after I severely modified them. I am straight up with my service advisors, though. I'll do the same with this car. Push comes to shove, building the motor is an option |
FSociety3812.50 |
