10-14-2018, 06:15 PM | #1 |
Rep 1,469
Slots and Dimples disappeared on M Perf rotor...
How is this possible? Are they just that worn down? Also, my pads look like they have nothing left after 2 track days and 3 months of driving. Anyways, i did not think the slots and dimples could disappear. Can i still drive this thing or do i need to replace ASAP?
You can see how it had the slots and dimples at one point. Grooves gone. Pad wear.
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
10-14-2018, 07:22 PM | #3 |
Rep 1,934
Yup. Time to get new rotors. May as well do pads at the same time, however, you could still get a couple months out of those.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
nissanite45.50 |
10-14-2018, 08:05 PM | #4 |
Rep 1,469
Damn i guess ill have to get new rotors and pads. I am going to be storing the car in 30 days so it wont be driven that much more. Hopefully it will be ok for another month. Ill just monitor it each day.
10-14-2018, 10:30 PM | #6 |
¯\_(ツ)_/¯
950
Rep 1,763
Order the rotors/pads from FCP since they have lifetime warranty. You can wear down the brakes again and they will replace it with new ones. Just pay shipping to send it to them and that's a lot cheap then buying everything new each time.
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
10-14-2018, 10:36 PM | #7 |
Rep 1,469
10-15-2018, 10:14 AM | #8 |
Rep 192
Although a bit much, 20k miles for a set of very aggressively driven rotors in a high-powered, heavy car with some track time on them is not completely crazy... Specially depending on what pads you're running.
Are the grooves gone on both sides of the disc? Are they gone on both discs? What pads are you using? |
10-15-2018, 10:24 AM | #9 |
Rep 937
Isnt it normal wear/tear... so they wouldnt cover it under warranty?
Hi
10-15-2018, 10:38 AM | #10 |
Rep 16,197
10-15-2018, 10:41 AM | #11 | |
Rep 1,469
10-15-2018, 10:48 AM | #12 |
¯\_(ツ)_/¯
950
Rep 1,763
I've seen a few pages on instagram with people who tracked and showed pics of the used rotors going to fcp and them taking it
10-15-2018, 11:39 AM | #13 |
Rep 1,469
FCP even states they cover wear and tear. It's part of their policy.
10-16-2018, 11:04 AM | #14 | |
Rep 192
I'm not familiar with the PowerStop pads, but aggressive pads will eat rotors. I have a couple of friends that are very fond of Carbonne Lorraines because of the stopping power and fade resistance but they are essentially changing discs very time they change pads. This is on a Renault Clio and a Nissan Pulsar so rotors are cheap. Not so much on an F3X... |
10-17-2018, 07:51 AM | #16 |
Rep 775
Slits and dimples are really only needed when wet imho as it helps with wiping effect. Other than that, you're reducing the ability of the pad to make direct contact with the rotor's metal surface, thus reducing grip potential. Furthermore, those dots and slots add more wear to the pad.
Am i surprised at the high wear rate during track events? Absolutely not. That's normal. Yes, check rotor thickness and obviously you know the pads need to be replaced. That's all part of tracking as car. Normal stuff really.
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
10-17-2018, 10:00 AM | #17 | |
Rep 1,934
I've had setups with cross drilled holes and it wasn't this bad, although I had hawk HPS ceramic pads. I believe its his tracking, and braking habits on the street that are the culprit here. Brake earlier on the streets and, coast more.
10-17-2018, 10:56 AM | #19 |
Rep 3,549
It's more of his braking than the actual rotors. I put 4 track days and 7mo/12k mi of driving on MSport rotors and didn't even wear them down 15% (I measured and compared to BMW specs before selling to a friend).
10-17-2018, 11:01 AM | #20 |
Rep 1,469
It could be the pads. They are aggressive. Sparks literally fly when i brake. I am running the power stop track days. They are like anchors but the dust level is too much for daily. They can also be very loud. I may just run m pads and maybe power stops on track only.
10-17-2018, 08:59 PM | #21 | |
Rep 1,934
Its actually more difficult to tell if the rotors are worn past the min thickness since the drilled holes go ALL the way through the rotor. With the dimples you will know, just with a glance, as to how much smaller the dimples have become, or in this case completely gone. With the cross drilled rotors you have to physically run your fingers across the outer edge to see how deep the outer ridge has become. And then it's still kind of just a guestimate. Plus the cross drilling actually makes the rotors more prone to cracking (right from the drilled holes outward). Moreover there's less rotor material to dissipate heat. BUT cross drilled rotors look much better IMO.
10-18-2018, 05:22 AM | #22 |
Rep 775
But being King of the Late Brakers is soooooo much more fun. Just ask my wife
Enjoy the Drive,
