10-16-2018, 10:49 AM | #1 |
Rep 117
F22 228 xdrive drone/vibrato engine noise
I recently purchased a 2015 228 xdrive with automatic transmission. I love the car but I hear a subtle drone/vibrato noise coming from the engine at 1k rpm in any gear. The noise disappear at lower or higher rpm. The car is still under warranty and I explained the issue to my dealer. They tried the car and said it was perfectly normal. Anyone experiencing something similar?
Now I also noticed a similar noise when accelerating full throttle, the noise can only be heard from 50 to 55 mph. I can't hear it cruising at that speed. No apparent vibration either. What could it be? Thanks for any input. |
10-30-2018, 07:38 PM | #3 |
Rep 117
I'm not really driving around at 1k, but when I come to a stop the automatic transmission goes around 1k before switching to the lower gear.
In any case I can hear the vibration also in neutral, it makes the noise only passing over 1k, not lower or higher. |
11-01-2018, 02:16 PM | #4 |
Rep 2,878
You may be experiencing new-owner-syndrome. I know I had it for my first 2 or 3 months - all kinds of odd little noises that I hadn't noticed in other cars (but I assume totally benign - like the noise when the auto-temp releases some Freon behind the dash or whatever it is doing). There would be expected to be some particular harmonics in exhaust and gear noises that vary with rpm, or only show up at certain places. Rest assured that these cars are smart enough that they'll throw a code if anything is starting to look seriously out of spec.
11-01-2018, 03:44 PM | #5 | |
Rep 117
Thanks |
Tags |
228i, f22, n20 |
